05 s60r automatic no forward gears
jboncher01
- Year and Model: 1997 850 GLT
- Has thanked: 3 times
So I am looking at picking one up that has no forward gears working although reverse does work. Wondering if something with the angle gear could cause this or if it's transmission related. It has about 160k on it.
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
If you have reverse but no forward gears it's very likely the C1 forward clutch in the transmission. It's either slipping very badly or not engaging at all, either way the transmission would have to pulled out repaired/rebuilt. There is a C1 pressure tap that could looked to determine if it's a fluid pressure problem when C1 is engaged.jboncher01 wrote: 30 Nov 2022, 09:12 So I am looking at picking one up that has no forward gears working although reverse does work. Wondering if something with the angle gear could cause this or if it's transmission related. It has about 160k on it.
- 24 Replies
- 3538 Views
Last post by Sommerfeldt
- 904 Views
Last post by JRL
- 1668 Views
- 1328 Views
- 826 Views
Last post by rspi
