15 XC60 T5 AC Compressor
AC Compressor replacement. What is the "easiest" way to remove the compressor? There doesn't appear to be enough room to remove from underneath the vehicle. If it has to be removed from the top, are there any directions or tips available online? I've researched exhaustively and can't find anything on point. Thank you in advance for any replies.
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
Hi sflorin,
I have the procedure from VIDA attached for you. The AC compressor swap involves a getting few other components like belt, tensioner and alternator out the way, and the proper way to disconnect/reconnect battery, so I have included those procedures as well.
Assuming you are proficient with recovery, pulling vacuum and recharging - I skipped those - however if you need the details please let me know (post or PM).
Hope this helps
Hope this helps
AC Compressor.pdf- (384.56 KiB) Downloaded 218 times
Battery.pdf- (165.84 KiB) Downloaded 167 times
Belt Tesnioner.pdf- (87.28 KiB) Downloaded 147 times
Belt.pdf- (304.03 KiB) Downloaded 114 times
Generator.pdf- (422.77 KiB) Downloaded 150 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- regent
No problem, stay safe!
2015 BMW 335i
2015 BMW 335i
