15 XC60 T5 AC Compressor
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
sflorin
Year and Model: 2015 XC60
Post by sflorin »
AC Compressor replacement. What is the "easiest" way to remove the compressor? There doesn't appear to be enough room to remove from underneath the vehicle. If it has to be removed from the top, are there any directions or tips available online? I've researched exhaustively and can't find anything on point. Thank you in advance for any replies.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Hi sflorin,
I have the procedure from VIDA attached for you. The AC compressor swap involves a getting few other components like belt, tensioner and alternator out the way, and the proper way to disconnect/reconnect battery, so I have included those procedures as well.
Assuming you are proficient with recovery, pulling vacuum and recharging - I skipped those - however if you need the details please let me know (post or PM).
Hope this helps :D
AC Compressor.pdf
(384.56 KiB) Downloaded 218 times
Battery.pdf
(165.84 KiB) Downloaded 167 times
Belt Tesnioner.pdf
(87.28 KiB) Downloaded 147 times
Belt.pdf
(304.03 KiB) Downloaded 114 times
Generator.pdf
(422.77 KiB) Downloaded 150 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
sflorin
Post by sflorin »
This is great. Thank you so much for taking the time to provide these!
Regards,
Scott
regent
Post by regent »
No problem, stay safe!
2015 BMW 335i
