vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Volvo's 5 cylinder engine is an open deck construction, its cylinder sleeves eventually get a taper towards the cylinder head, which forces compression rings to open wider in the upper part of the sleeve. Also the rings themselves are likely worn, not very elastic and the gap is too large, to begin with. Also the sleeves are out of round, which causes all the rings to orient in such a way that their thermal gaps are aligned in one line. That's really bad for the crankcase blow-by gases (PCV has to work harder), as well as it allows much more oil be sucked in during the intake stroke.
No cure, except replacing the piston rings with new ones. And yet this is not a long term solution, because of taper and general bore wear.
This engine is good, but not worth rebuilding without a significant construction change at high mileage, like Darton sleeves, in my opinion.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
vtl wrote: 07 Dec 2022, 08:24 Volvo's 5 cylinder engine is an open deck construction, its cylinder sleeves eventually get a taper towards the cylinder head, ....
That's really interesting, what causes that? Is it temperature at the top of the cylinder? Erosion from combustion?
vtl
Post by vtl »
BlackBart wrote: 07 Dec 2022, 10:28
Thin cylinder walls in 2.4 and, especially, in 2.5 that don't hold well a naturally higher pressure in upper part of the combustion chamber. Add occasional detonations.
BlackBart
Post by BlackBart »
So they gradually bow out (microscopically) at the top? Wow.
vtl
Post by vtl »
BlackBart wrote: 07 Dec 2022, 10:41 So they gradually bow out (microscopically) at the top? Wow.
Yeah. This is what Volvo permits:
This is what engine from the donor car w/ 220k miles on the odo had (I was swapping out crashed chassis and took its working engine apart out of interest):
Out of round 2 is near the top of the bore, 1 is around the center.
Willber
Year and Model: 2.4t 2002
Has thanked: 5 times
Post by Willber »
Thansk, vtl, really interesting!
Do you think that my smoking is probably piston rings rather than stem seals or valve guides then, if it only occurs after long periods of high vacuum / engine braking, rather than after idling or upon start up?
vtl
Post by vtl »
Willber wrote: 08 Dec 2022, 07:32 Thansk, vtl, really interesting!
Likely, both. It is a good idea to replace valve stem seals, though. At this age/mileage they are long time not elastic and badly worn.
It is not an easy job to do with the engine still in the engine bay. Exhaust valves are barely accessible, you must drain oil from the camshaft valleys and degrease valve guides with acetone super-thoroughly, otherwise the new seals will fly off.
Also exhaust seals better be Volvo original. Others commonly fail in 20-30k miles. Intake could be Elring. I personally put OE/exhaust (very expensive) and Elring/intake.
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
I sold my P2 today.
vtl
Post by vtl »
gnalan wrote: 09 Dec 2022, 12:22 I sold my P2 today.
Any plans?
gnalan
Post by gnalan »
vtl wrote: 09 Dec 2022, 12:39 Any plans?
I have a Mustang now.
