1998 v70 NA M56 CV boots
Has thanked: 1509 times
Been thanked: 3827 times
Resolved with the 1998 NA cv jointbboot Wiki....
  • front left boot Volvo part number GKN
    Front left inner boot Volvo part number GKN other
    Front right inner boot Volvo part number GKN
    Front right outer boot Volvo part number GKN
Having trouble sourcing these
Outer boots easy
GKN 300427 kit complete with nut, fits Both sides
Inner boots.
Driver side takes a 28 mm shaft diameter , roughly 90 mm CV diameter. The boot is just round inside
Passenger side has tripod style with 80 mm across and 40mm axle diameter. The boot is complex with inner ears to seal the complex shape of the bearing cup
Has thanked: 1856 times
Been thanked: 1717 times
Do you have a Volvo or GKN part number? I have some GKN boots here but not sure of what they fit other then my 'R' but I also have another waif and not sure what it is for.
The only one I have found so far is a kit made by 'Empi' (oh the horror!) at IPD:
https://www.ipdusa.com/products/21765/I ... 649-246708
Your friends at FCP Euro show an inner GKN boot for a 98 V70 NA??
https://www.fcpeuro.com/products/volvo- ... o-31256227
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Was just looking at this site as I know Saab was in the general area as Volvo... I'm guessing they used some of the same transmissions but don't quote me on it.
https://www.rendcarparts.com/en/product ... 247&page=2
Shaft diameters quoted above are wrong. I was measuring stub axle diameter
So did you get the boots after all?
GKN 303946 is the scalloped boot , inner passenger side
rrres
Year and Model: 1999 v70XC
Has thanked: 10 times
Been thanked: 26 times
Post by rrres »
I got my inner passenger side of the '99 from Rockauto. Not sure if it's the same for your vehicle but it was a Rein BKN0132. It says that it replaces 31256221.
It's blowby
rrres wrote: 14 Dec 2022, 18:06 I got my inner passenger side of the '99 from Rockauto. Not sure if it's the same for your vehicle but it was a Rein BKN0132. It says that it replaces 31256221.
Definitely not the right one on the 1998 NA. That app shows an outer boot with a 14mm axle screw too, so I doubt it will fit an inner on any car
And here are the ones that fit.
The -300497 for the outers
The -303946 fit the inner passenger
The Empi fits the inner driver
wizechatmgr
EMPI is
EPI-862333D (FCP part number)
