Background Info
I have a 2004 S60 R M66, I had a busted outer CV boot on the driver side. I replaced both of my axles just for safe measure since I’m at 160k miles. both of them came out and went in perfect! I replaced them with TrakMotive V0-8035 ( Driver side) and VO-8041 (pass side) as seen on a lot of other forums these seem to be the closest direct OEM fit.
Here’s my issue!
Drove the car 3-400 miles, axles felt good etc. I let the clutch out after normal driving conditions, I heard a loud bang and lost all gears. I securely got the car in a parking lot and confirmed the axle popped out. I tore the car down today, pulled the axle out to see if I installed incorrectly and discovered I snapped the driver side axle off just after the CirClip inside of the differential. The CirClip is still intact but the remaining splines are stuck inside of the housing.
Has anybody experienced this before or have any helpful tips to get it out? I’ve read probably a dozen forums about this to not find any concrete solution.
Here’s my question
1. Is the pass & driver side differential straight thru?
a. Can I take the passenger side axle out and get a long chisel/ punch and push the Circlip and the remaining axle spline fragments on the driver side out?
b. do I have to drill and tap a bolt and use a slide hammer to extract it?
c. am I pulling the Transmission, Differential and angle gear out to even knock this thing out?
2. scale of 1-10, will this repair make me fully willing to scrap the car
3. Can somebody please recommend me an alternative axle brand.
If anybody has the slightest idea or recommendation please comment, I’m truly lost and have 0 clue how to proceed.
