axle broke inside differential
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Think I would’ve drilled a whole in the remaining stump and used a dent puller to get it out. Things like that happening is really annoying. Hope you get it sorted out.
BMW 540i 2002
S70 Base 2000
- Been thanked: 4071 times
What an epic Charlie Foxtrot. Let’s scratch that axle maker from our parts lists.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
If he drills through, he will damage a differential cap.kallekula wrote: 11 Dec 2022, 22:41 Think I would’ve drilled a whole in the remaining stump and used a dent puller to get it out. Things like that happening is really annoying. Hope you get it sorted out.
- kallekula
Ok pull the transmission then, disassemble it and while you’re at it change out the friction plates and inspect bushings etc.
I would try drilling or welding something onto it etc before I did that.
EDIT: see now it’s probably a manual. Dunno what they look like inside. What is that “cap”? Anyhow, welding something onto it that u can get a grip on with the puller should work. Or maybe there’s a much better way. Once clip is gone a strong magnet might be able to get it out.
BMW 540i 2002
S70 Base 2000
vtl
A proper rebuild is very expensive, laborious, requires precision tools and outsourcing a part of work to other hands (torque converter rebuild, sleeving the worn case). Even changing friction plates alone would require precision tools to measure the new gaps (or lack of those) and picking the right shims, otherwise he can ruin it all. Mine cost me $3k in total, I had to rebuild it twice, because I'm cheap and decided to rebuild my Sonnax valve body vs buying a new one. In 3 miles everything was covered with friction dust.kallekula wrote: 12 Dec 2022, 06:53 Ok pull the transmission then, disassemble it and while you’re at it change out the friction plates and inspect bushings etc.
Taking out the differential only requires a removal of torque converter and splitting the case in half. Oh, the new filter, while it's accessible.
That's the brown thing you see inside the differential when the axle is out, it keeps ATF inside the transmission. You don't want to see something like that:
- kallekula
Yeah I rebuilt my AW55-50 a while back. Didn’t cost me 3K though. I don’t remember that cap but the problem here is a manual right?
BMW 540i 2002
S70 Base 2000
- Has thanked: 987 times
- Been thanked: 1076 times
Someday I would like to say - "I rebuilt my automatic transmission and it works great now."
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I think his with the broken axle is a M55.
2003 XC 70 (sold)
- Has thanked: 311 times
- Been thanked: 817 times
Top of the first post and in OP's profile info: it's an M66. Not an AW55.
- 1876 Views
Last post by June
- 619 Views
Last post by Blacklab467
- 1832 Views
Last post by 93Regina
- 3227 Views
Last post by jimmy57
- 867 Views
Last post by cn90
