98 V70 T5 brake pedal sinks *SOLVED* Topic is solved
valvolvo70
Year and Model: 1998 V70 T5 249K
Has thanked: 10 times
Been thanked: 8 times
Post by valvolvo70 »
I've only been able to check master cylinder fluid level (good) and leaks (none), its dark. Driving yesterday and noticed the brake pedal gets soft occasionally as I stopped/slowed. Realized today that the brake pedal gets soft and sinks when TURNING RIGHT only? It will eventually stiffen with a few pumps. TEST: No brake pedal sinking when slowing to a stop driving straight or while slowing/turning left, just right turns, which can be challenge when pulling into a parking spot :o I haven't changed the fluid in a few years and its cold 30-40 F.
Has thanked: 1503 times
Been thanked: 3817 times
It could be a collapsing brake line on either side which is getting extended in turning. Inspect both front sides.
valvolvo70
abscate wrote: 11 Dec 2022, 16:07 It could be a collapsing brake line on either side which is getting extended in turning. Inspect both front sides.
Yes. Thank you, Ill check in the a.m. Both front tires where replace a couple weeks ago, wonder if the line(s) were messed with during installation.
valvolvo70
Time for new lines! Wet tire and concrete under the split hose.
valvolvo70
**UPDATE took a week to get parts/bubble flare kit so I could cut and flare the V70 hard brake line today. Bit of a PITA but went well and NO LEAKS! Many years ago I had to run new hard break lines front to rear on a rusty 4runner actuator line, I posted my "pro tip" on a Toyota forum site and it worked well again today while hand bending (w/pliers) V70 front hard lines from radius to flat to radius again. If you don't have a break line bender or space is an issue, simply insert the appropriate diameter weed wacker line (.080) into the brake line prior to making bends. The weed wacker cord keeps the brake line walls from collapsing or kinking during the forming process. Make any size radius with your hands or tools like pliers! Thanks to jreed for his write up, came in handy.
step 2 brake line.jpg (96.86 KiB) Viewed 442 times
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
valvolvo70 wrote: 02 Jan 2023, 16:25 ...my "pro tip" on a Toyota forum site and it worked well again today while hand bending (w/pliers) V70 front hard lines from radius to flat to radius again. If you don't have a break line bender or space is an issue, simply insert the appropriate diameter weed wacker line (.080) into the brake line prior to making bends. The weed wacker cord keeps the brake line walls from collapsing or kinking during the forming process. Make any size radius with your hands or tools like pliers! Thanks to jreed for his write up, came in handy.
Fantastic idea! I haven't had to mess with the hard lines on the Volvo.... what size hard lines do our cars use?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
valvolvo70
454cid wrote: 02 Jan 2023, 17:42
Thank you! Hard lines are 3/16" (4.7mm). I would recommend purchasing the flare nut wrenches to avoid having to cut/flare the hard line. Mine were rusted to sh*t (MI winters) so I had to cut.
valvolvo70 wrote: 02 Jan 2023, 16:25 **UPDATE took a week to get parts/bubble flare kit so I could cut and flare the V70 hard brake line today. Bit of a PITA but went well and NO LEAKS! Many years ago I had to run new hard break lines front to rear on a rusty 4runner actuator line, I posted my "pro tip" on a Toyota forum site and it worked well again today while hand bending (w/pliers) V70 front hard lines from radius to flat to radius again. If you don't have a break line bender or space is an issue, simply insert the appropriate diameter weed wacker line (.080) into the brake line prior to making bends. The weed wacker cord keeps the brake line walls from collapsing or kinking during the forming process. Make any size radius with your hands or tools like pliers! Thanks to jreed for his write up, came in handy.
That is an awesome tip, thanks for posting. Still learning!!
valvolvo70
More info and a finished image.
V70 frt brake line.jpg (506.46 KiB) Viewed 386 times
