iPhone 4 camera uncooperative at times. Repair pics on the failed item only partially successful.
Nice and shiny from Mother Göteborg
After the rollback ride, I did a temp fix so I could yard drive it while waiting for the new pedal ( see "...TASCA..." for that adventure.)
The broken pin stayed with the clutch control cable, I was able to wrestle a wire tie through the loop of the clip and stick the broken stub back into the pedal.
'98-'00 clutch pedal 9191520 repair
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
- Has thanked: 1853 times
- Been thanked: 1714 times
Creative thinking indeed! What can't be fixed with some wire, duct tape and zip-ties?!!
- foggydogg
The failure sequence likely started a while ago. The edge of the pin at the break shows some age; it just took a while for the pin to ease out of the pedal and the whole mess fly apart. The pedal went to the floor and stayed there. Me: walking. Car: rollback.
Hard to see but the remnants of the pedal side of the pin shows the break was inside the stamping, not at the factory weldment.
...and there is a witness mark where the collar rocked back and forth for a bit.
The pedal isn't bar stock or a casting, it's actually a pretty complicated stamping mandrel bent, and welded together along the seam,
...then lots of other stuff happens to it.
- foggydogg
Once it was cleaned up it was time to test long-dormant fabrication skills.
The pedal side of the pin must have been pushed through a close tolerance hole on the outboard side, probably a little proud of the stamping, and surface welded. Didn't get a before pic. The trick was finding the center; the plan was to drill enough material to allow plug welding from the outboard side, but leave enough of the stub to give the weld more base material than the pedal stamping itself. The jagged moonscape of the remnant made getting it centered from the inside a bit of a challenge.
Once the pilot was sort of where it needed to be, the hole was stepped up in a couple of gulps.
Happy with both sides, on to the squeaky clean phase.
- foggydogg
The collar on the pin remnant showed a small gap between it and the stamping on the inboard side, so it was tacked first,
...then the outboard side was plug welded, and finally the collar was finish welded.
Neither the original pedal nor the replacement were welded on the inboard side.
- foggydogg
Cleaned it up a bit,
...keeping in mind if it has to go back in a car, it is buried pretty deep. Nobody will know what it looks like. Welding skills have a pretty short shelf life, so no rock-throwing at my gobs, please. It's been a while since I struck an arc in anger.
- Has thanked: 1506 times
- Been thanked: 3821 times
Nice. Those vintage vice grips, outsourced to China in 2008 by Rubbermaid, are now being manufactured again in DeWitt, NE by Malco
I won’t be buying the Vice grip name anymore from Wall Street.
- Has thanked: 928 times
- Been thanked: 1002 times
Nice fab work.
Glad Vise Grips are once again made in Corn Husker land.
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
Unfortunately, it seems they weren't able to make a go of it: https://www.eaglegripusa.com/
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid wrote: ↑22 Dec 2022, 00:48Unfortunately, it seems they weren't able to make a go of it: https://www.eaglegripusa.com/
Well, crap on rye.
There is still some inventory on Amazon, with the MVS link of course
