What is this clip I found in my 99 S70? Topic is solved
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
I found this while vacuuming awhile back. Where did it fall off from? It's been sitting on my desk, and I'd like to put it back where it goes, or toss it.... last time I tossed something I found in the car, that I couldn't identify and couldn't imagine being a Volvo part, was a Volvo part. It was the front license plate spacer.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1856 times
Been thanked: 1717 times
Where in the car did you find it?
454cid
Post by 454cid »
scot850 wrote: 25 Dec 2022, 16:19 Where in the car did you find it?
I don't remember, for sure. It may have been in the pocket in the driver's door, or it might also have been in the storage pocket under the glove box. I had the idea that someone had found it before me, and placed it there.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
It is made to clip onto a flat surface like sheet metal then hang another part. I would be checking for loose interior panels.
454cid
Post by 454cid »
RickHaleParker wrote: 25 Dec 2022, 18:18 It is made to clip onto a flat surface like sheet metal then hang another part. I would be checking for loose interior panels.
I do have the panel under the steering wheel that's loose on one side. I'll see if I can figure out how to remove it the rest of the way.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Has thanked: 1509 times
Been thanked: 3827 times
Interior trim piece clip of some sort. It’s driving me nuts as I’ve seen it somewhere and can’t remember
Clemens
Has thanked: 475 times
Been thanked: 219 times
Post by Clemens »
abscate wrote: 26 Dec 2022, 01:08 Interior trim piece clip of some sort. It’s driving me nuts as I’ve seen it somewhere and can’t remember
Ask your canine friend in the back seat. He has better vision and a younger brain. :D Just like my kids ...
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
454cid
Post by 454cid »
I'll keep it then, but move it off my desk into my "Volvo box". I think it might be the panel below my steering wheel. I tried pulling on it today, but then noticed a screw and some tar like glue holding it on. It's too cold for me to want to mess with it enough to get tools out, and clean up some black goo.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
the black goo, particularly on the driver's side under tray on the dash it likely because the center screw mount has broken up or one of the 2 slots that the try slides into at the front has torn. The black goop is to hold it in place I'm guessing.
RickHaleParker
454cid wrote: 25 Dec 2022, 21:29 I do have the panel under the steering wheel that's loose on one side. I'll see if I can figure out how to remove it the rest of the way.
It might be for a drain hose under one of the Pillar trims.
