850 1995 Idling up and down Topic is solved
manovlov
Has thanked: 620 times
Been thanked: 143 times
Re: 850 1995 Idling up and down
Post by manovlov »
abscate wrote: 26 Dec 2022, 04:55 Cleared customs this morning! If you use WhatsApp,I can send you the link to tracking by phone ( or use email)
I send you my phone number by mail.
manovlov
Post by manovlov »
I've installed the part received this morning. No change. The idling goes normal and when the engine begins to be warmed, it stops. The coolant gauje doesn't move up also. The fan started to turn a while then stopped. The relay is a bit warm which could be normal when the fan has spinned a little.
I've replace the IDLE Control Valve : no change.
I've replaced the MAF : no change.
Could it be the throttle position sensor ? I've ordered a new one that should be here Thursday.
The lambda sensors ?
Capture d’écran 2022-12-27 à 12.33.27.png (28.91 KiB) Viewed 484 times
So i don't want to try to drive the car if l’m not sure to be able to come back home...
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
ECT sensor or it's wiring.
Check from both....sensor side and engine wiring loom side.
Engine temp gauge and cooling fan behavior are classic symptoms of bad ECT(or it's wiring).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
manovlov
Post by manovlov »
misha wrote: 27 Dec 2022, 05:10 ECT sensor or it's wiring.
I will check these points, but my ECT sensor is new which doesn't mean that it couldn't be out ... My buddy at Volvo told me that it might come from the knock sensor I've badly screwed (understand, not enough when i did my PCV kit - i unscrewed it by mistake). He also recommends me to control grounds contact points.
And I've ordered lambda sensors because after 20 years, it can't hurt.
Thanks for you advice misha.
misha
Post by misha »
Dead and erratic temperature gauge in the instrument cluster can't be from bad knock sensor.
Ect is brand new....is it oe Volvo or something aftermarket?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
manovlov
Post by manovlov »
I've replaced it while i was doing the PCV kit. It's true that the issue came just after. I've driven 200 kms before to see appear the trouble... I will test the thing whit the old one.
It's a FAE
Capture d’écran 2022-12-27 à 23.30.00.png (131.45 KiB) Viewed 438 times
Here's my choice (if one is correct...) :
Capture d’écran 2022-12-27 à 23.36.13.png (12.86 KiB) Viewed 438 times
What should i take ?
misha
Post by misha »
Remove it and toss it in the bin!
You are chasing your tail with this crap.
Oe Volvo or at least Vernet.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1853 times
Been thanked: 1714 times
+1 with Misha on the ECT.
manovlov
Post by manovlov »
all right Guys. I will order one to Volvo. Thanks.
johncreat31
Year and Model: 2021
Post by johncreat31 »
I would look into the 141 and 122 for your engine issues. 122 may be the engine coolant sensor (ECT) at the thermostat, I am not sure on what 141 is triggered by as you car is not fly by wire. I'll have to do some research!
hellodear.in
tea tv apk
