Best Place To Drill Into Center Console 1998 v70
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Re: Best Place To Drill Into Center Console 1998 v70
Post by MrAl »
WhatAmIDoing wrote: 05 Mar 2023, 11:48 The carpet just tucks under the console. There's not really any adhesive holding it down. Removing the console is easier than you think. I watched Robert's video and it took me less than 10 minutes in the junkyard.
Yes i watched it too now and i see it's not that bad. I'd love to see what is hiding under there anyway.
I never knew there was a trap door at the bottom of the console compartment.
With this fix i will also be able to get a look at the wire size used for the OBDII connector which has been a question i had on my mind for some time now.
Thanks.
Has thanked: 1850 times
Been thanked: 1712 times
Absolutely!
MrAl
Post by MrAl »
scot850 wrote: 05 Mar 2023, 17:15 Absolutely!
Will be very interesting. It's sort of like a hobby with me now. It's too bad i have to go down two flights of stairs to work on it though that's a real pain in the neck. If you forget something, back up two flights to get it then back down again.
