MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
MooseGangJP wrote: 05 Mar 2023, 17:44 Pics
01 S60 Solenoid.png (1020.46 KiB) Viewed 587 times
Was your original solenoid with a straight connector like mine so you had to splice the wire? I was considering replacing mine with the side connector as the straight connector solenoids are hard to come by and more expensive. The gasket and body looks the same and could interchange as the function of the solenoid should be generic.
Has thanked: 1611 times
Been thanked: 4075 times
Ugh. Those proParts Sweden solenoids aren’t known for their friendliness
WiseSer5512
Year and Model: 2006 V70 2.5T
Post by WiseSer5512 »
I’m trying to start it, still. Removed wipers today to take big good lock to CEM connectors, which probably (but hopefully not) the reason why car wouldn’t start. Next step probably will be checking all the CEM fuses + ECM, cause car will not connect these by any reason and wouldn’t start
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
WiseSer5512 wrote: 07 Mar 2023, 01:22 I’m trying to start it, still. Removed wipers today to take big good lock to CEM connectors, which probably (but hopefully not) the reason why car wouldn’t start. Next step probably will be checking all the CEM fuses + ECM, cause car will not connect these by any reason and wouldn’t start
Read the codes with DiCE/VIDA. The car literally tells you what is broken. You click on any code present, and VIDA have a walk through that points to an actual problem with 90% of confidence.
Replacing relays is pain in L-shaped CEMs. It is hard to take these CEMs out, it is hard to disassemble them, it is hard to desolder a broken relay (need a soldering station with hot air). Volvo Cars made sure you better pay $1600 for a new CEM (or, better, spend 1/2 of new car price in two years leasing it out), unless you're stubborn and dedicated to break that ill "buy new" economy by fixing the CEM for $7.99.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
vtl wrote: 07 Mar 2023, 06:57 It is hard to take these CEMs out, it is hard to disassemble them, it is hard to desolder a broken relay (need a soldering station with hot air). Volvo Cars made sure you better pay $1600 for a new CEM (or, better, spend 1/2 of new car price in two years leasing it out), unless you're stubborn and dedicated to break that ill "buy new" economy by fixing the CEM for $7.99.
Are there any photos of how this looks?
vtl
Post by vtl »
BlackBart wrote: 07 Mar 2023, 07:12 Are there any photos of how this looks?
Of course! I was chasing a "no power to BCM". Last photo is what explaining those $1600 in Volvo Cars cocaine dreams.
WiseSer5512
What the car says - is that she has problems with ECM and CEM at the same time- they cant connect, error codes are ECM-8210 which is a relay error (system relay signal faulty), CEM-1A62 which says that there is no connection to ECM (missing signal of communication with ECM control module). At the same time when I'm reading all codes automatically - I can see CEM reports, but when I'm trying to read CEM manually, it just says "failed to communicate", so Im guessing that the CEM is bad
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
I had to replace the same relay on the REM. I got zero resistance on the coil. This was causing ANTI SKID to be out service because the REM communicates to the DEM. I purchased the AZ980-1A-12DE relay from www.digikey.com.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Changed the cabin filter, I think the old one had been in there since the car was built
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
vtl
Post by vtl »
P80GLT wrote: 09 Mar 2023, 06:36 Changed the cabin filter, I think the old one had been in there since the car was built
You have a better choice in Europe: Mahle LAO54, with antimicrobial layer. We've had it in US for some time, too, but I can't find it anymore. Even had the same LAO series filters in my big Toyotas, no longer sold as well.
