Engine code after cleaning Exhaust VVT Topic is solved
dksoutha
Year and Model: 2006 XC70
Has thanked: 7 times
Post by dksoutha »
Had a stuck exhaust VVT. Cleaned it ultrasonically (did not clean the rubber grommet,) and now parts move freely. After putting it back together I am getting a different engine code, which I forget at the moment but will go out to get that in a minute. Should I have done something specific when cleaning that VVT?
2006 XC70 base
Oly850
Year and Model: In acquisition mode.
Has thanked: 53 times
Been thanked: 22 times
Post by Oly850 »
I don’t think my ‘96 850 had VVT, and they introduced them on the intake side first in later models. In any case, a VVT solenoid is electric and shouldn’t be wet, but the sprocket it acts on is all metal, is this what you cleaned?
Looking for a V90 to be my next Volvo, at the very least a T5.
2017 XC90 Inscription - My best Volvo by far, but Ex-wife departed & I had to sell. 😕
2001 S80 T6 - rebuilt trans, head gasket, fixed & sold
1997 V70 - kid car, sold
1996 850 GLT - found under bridge, 2 year refurb project, commuter car, kid car, T-Boned - SIPS saved passenger. Totaled.
1997 VW GTI VR6 - exceedingly fast.
1971 VW Type II/231 - it was pointed out by management that the children would be killed in it.
dksoutha
Post by dksoutha »
Yep, just the metal parts, thanks. I left the electronic part out of the cleaning solution, along with the rubber grommet. The engine code (P03**?) has gone away since my last post...hmmmmm. I do have a P0017 code, but that predates the VVT cleaning. I have not cleaned or changed the oil separator box under the intake manifold and suspect that is the source throwing the code. I do welcome any suggestions as to what else could be causing the P0017.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
p0017 is timing related, who did the timing belt ?
Oly850
Post by Oly850 »
Yeah P0017 is bank 1 (intake/front) camshaft does not swing by it’s hall sensor when the ECU predicts it should. This could be the crankshaft being off +- 1 or 2 teeth or the same for the intake cam. The procedure for the front cam has to be followed precisely. Rather than hose your engine, have a good rest, eat breakfast and remove / replace the timing belt. I usually have to find the timing mark on the crankshaft pulley with my little finger and push toward the block to find the corresponding ridge.
Has thanked: 1502 times
Been thanked: 3817 times
You have to follow the cam timing procedure precisely on VVt cars, it is not just as simple as aligning the marks.
