Computer Code Explainations
cobyco
Year and Model:
Post by cobyco »
I have two computer code errors on my 2002 XC70 -P2907 and P0607 - Can anybody tell me what they mean so when I can possibly get the parts and fix the old gal myself.
thanx in advance for any help
Coby
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I find absolutely nothing for your first code...your second code I found here (not specific to Volvo's): http://www.tankota.net/repair/Repair_Ma ... p06046.pdf
Somehow I higly doubt that your ECM (main computer) is kaput...if it were, you would get a ton of other codes. Check for continuity between the pins on your ECU and all wiring...make sure there's no corrosion (even your battery terminals and ground wires) and clean and reseat everything. You can also reset your codes (you'll need a code reader) to see if this is a one time only thing or if it's continuous. Good luck and post back.
VCA
Year and Model: 2008 S80 T6 AWD
Been thanked: 5 times
Post by VCA »
cobyco wrote:I have two computer code errors on my 2002 XC70 -P2907 and P0607 - Can anybody tell me what they mean so when I can possibly get the parts and fix the old gal myself.
Coby
P0607 translates to Volvo specific code ECM-711A: "Control module, internal fault." [Users of VADIS can find the conversion chart I used under Group 2, "Diagnostic Information/General Diagnostics and Test", subgroup 20, "Conversion table..."] And I quote VADIS: "Diagnostic trouble code (DTC) ECM-711A is stored if the engine control module (ECM) registers a fault in the internal circuit for the timer in the control module."
So, clear codes. If it returns, check charging voltage of the alternator (as this can sometimes affect the computer). Otherwise, you need a new ECM and an ECM reload. :cry:
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
MadeInJapan
I tried to post the following as the first answer here earlier but the site was being finicky...anyway, here it is:
Somehow I highly doubt that your ECM (main computer) is kaput...if it were, you would get a ton of other codes. Check for continuity between the pins on your ECU and all wiring...make sure there's no corrosion (even your battery terminals and ground wires) and clean and reseat everything. You can also reset your codes (you'll need a code reader) to see if this is a one time only thing or if it's continuous. Good luck and post back.
sirdani
Year and Model: 2002 S80
Post by sirdani »
VCA wrote: 14 Feb 2009, 06:51
Coby
I have the same code on a S80 2002. Have you fixed your ECM-711-A? If yes, how?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2658 times
Been thanked: 1248 times
Post by matthew1 »
Sirdani, please do not post to a number of threads looking for the same answer. Keep it to one or two.
Also -> Amazon link
sirdani
Post by sirdani »
matthew1 wrote: 26 Mar 2023, 17:02 Sirdani, please do not post to a number of threads looking for the same answer. Keep it to one or two.
As you can see there were some ECM-711A problems before in this forum. But none of them closed, we do not know the results. All of these topics are very old, and users may not active today. That is why I tried to reply all of them, maybe one of them still active today.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
sirdani wrote: 27 Mar 2023, 06:12
Start a new post, everyone will see it.
Post all the information car, mileage , other symptoms, have codes been read and reset yet, do you have vida, etc etc.
