I have two computer code errors on my 2002 XC70 -P2907 and P0607 - Can anybody tell me what they mean so when I can possibly get the parts and fix the old gal myself.
thanx in advance for any help
Coby
Computer Code Explainations
- Has thanked: 17 times
- Been thanked: 35 times
I find absolutely nothing for your first code...your second code I found here (not specific to Volvo's): http://www.tankota.net/repair/Repair_Ma ... p06046.pdf
Somehow I higly doubt that your ECM (main computer) is kaput...if it were, you would get a ton of other codes. Check for continuity between the pins on your ECU and all wiring...make sure there's no corrosion (even your battery terminals and ground wires) and clean and reseat everything. You can also reset your codes (you'll need a code reader) to see if this is a one time only thing or if it's continuous. Good luck and post back.
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
P0607 translates to Volvo specific code ECM-711A: "Control module, internal fault." [Users of VADIS can find the conversion chart I used under Group 2, "Diagnostic Information/General Diagnostics and Test", subgroup 20, "Conversion table..."] And I quote VADIS: "Diagnostic trouble code (DTC) ECM-711A is stored if the engine control module (ECM) registers a fault in the internal circuit for the timer in the control module."cobyco wrote:I have two computer code errors on my 2002 XC70 -P2907 and P0607 - Can anybody tell me what they mean so when I can possibly get the parts and fix the old gal myself.
Coby
So, clear codes. If it returns, check charging voltage of the alternator (as this can sometimes affect the computer). Otherwise, you need a new ECM and an ECM reload.
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
I tried to post the following as the first answer here earlier but the site was being finicky...anyway, here it is:
Somehow I highly doubt that your ECM (main computer) is kaput...if it were, you would get a ton of other codes. Check for continuity between the pins on your ECU and all wiring...make sure there's no corrosion (even your battery terminals and ground wires) and clean and reseat everything. You can also reset your codes (you'll need a code reader) to see if this is a one time only thing or if it's continuous. Good luck and post back.
I have the same code on a S80 2002. Have you fixed your ECM-711-A? If yes, how?VCA wrote: ↑14 Feb 2009, 06:51P0607 translates to Volvo specific code ECM-711A: "Control module, internal fault." [Users of VADIS can find the conversion chart I used under Group 2, "Diagnostic Information/General Diagnostics and Test", subgroup 20, "Conversion table..."] And I quote VADIS: "Diagnostic trouble code (DTC) ECM-711A is stored if the engine control module (ECM) registers a fault in the internal circuit for the timer in the control module."cobyco wrote:I have two computer code errors on my 2002 XC70 -P2907 and P0607 - Can anybody tell me what they mean so when I can possibly get the parts and fix the old gal myself.
Coby
So, clear codes. If it returns, check charging voltage of the alternator (as this can sometimes affect the computer). Otherwise, you need a new ECM and an ECM reload.![]()
- Has thanked: 2655 times
- Been thanked: 1248 times
Sirdani, please do not post to a number of threads looking for the same answer. Keep it to one or two.
As you can see there were some ECM-711A problems before in this forum. But none of them closed, we do not know the results. All of these topics are very old, and users may not active today. That is why I tried to reply all of them, maybe one of them still active today.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 481 times
Start a new post, everyone will see it.sirdani wrote: ↑27 Mar 2023, 06:12As you can see there were some ECM-711A problems before in this forum. But none of them closed, we do not know the results. All of these topics are very old, and users may not active today. That is why I tried to reply all of them, maybe one of them still active today.
Post all the information car, mileage , other symptoms, have codes been read and reset yet, do you have vida, etc etc.
- 1421 Views
Last post by rspi
- 716 Views
Last post by Sommerfeldt
