I was told the knocking is the drive belt tensioner. Not sure because it goes away in N or P. The squeaking is constant, but clunking aound goes away. At idle only, goes away when revving or driving
https://drive.google.com/file/d/1kxNrYy ... p=drivesdk
04 xc70 engine noise
- jonesg
- Year and Model: 2004 V70
- Has thanked: 70 times
- Been thanked: 482 times
Remove the belt and listen again, if you wait it will soon shred the belt.famfeld wrote: ↑25 Apr 2023, 16:01 I was told the knocking is the drive belt tensioner. Not sure because it goes away in N or P. The squeaking is constant, but clunking aound goes away. At idle only, goes away when revving or driving
When it shredded the belt it made a real mess on mine.
- Has thanked: 1507 times
- Been thanked: 3827 times
30 mm Hex on the P80 and I think P2 is the same.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 264 times
Perhaps this is another good reason to not remove the crankshaft bolt and pulley when changing the timing belt.
2003 XC 70 (sold)
