Any speculation on what the problem is here?
I will talk to the owner later this week about what happened when, until then would appreciate any thoughts such as how severe, what to check, etc. Engine is at 151k and I think it has had a mostly easy life, though I do not yet know about its maintenance routine.
Valves? lifters? Could it actually be the bottom?
Best case scenario the timing belt skipped 3 teeth and putting it back makes it all quiet down and run another 150k!
06 XC70 help with engine noise
- Has thanked: 293 times
- Been thanked: 766 times
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1507 times
- Been thanked: 3827 times
That does sound like a bad lifter vs bottom end to me.
It's not a failed front wheel bearing, is it?
In that case could it be a clogged pickup tube, or must be worse like an oil pump failure or some other blockage there?
I'll find out how suddenly it came on, if they kept driving it. And inspect for sludge, check the oil level.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
