04 xc70 engine noise
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
famfeld
Year and Model: 04 xc70
Has thanked: 9 times
Been thanked: 6 times
Post by famfeld »
I was told the knocking is the drive belt tensioner. Not sure because it goes away in N or P. The squeaking is constant, but clunking aound goes away. At idle only, goes away when revving or driving
https://drive.google.com/file/d/1kxNrYy ... p=drivesdk
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 482 times
Post by jonesg »
famfeld wrote: 25 Apr 2023, 16:01 I was told the knocking is the drive belt tensioner. Not sure because it goes away in N or P. The squeaking is constant, but clunking aound goes away. At idle only, goes away when revving or driving
Remove the belt and listen again, if you wait it will soon shred the belt.
When it shredded the belt it made a real mess on mine.
famfeld
Post by famfeld »
I'm going to be doing that tomorrow. Just occurred to me. I guess i panicked because i don't want any transmission or engine issues
famfeld
Post by famfeld »
Just checked belt and found crank pulley loose with center bolt missing. Strange how 2 trusted professional mechanics misdiagnosed this!
Thanks for the help
Feld
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Good catch!
jonesg
Post by jonesg »
famfeld wrote: 26 Apr 2023, 10:33 Just checked belt and found crank pulley loose with center bolt missing. Strange how 2 trusted professional mechanics misdiagnosed this!
Thanks for the help
Feld
Its a center nut no ?
32mm I think, something big.
Don't run it.
Has thanked: 1507 times
Been thanked: 3827 times
30 mm Hex on the P80 and I think P2 is the same.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
I lost that nut not so long ago, too. My 450 ft-lbs electric impact wrench failed me.
jonesg
Post by jonesg »
vtl wrote: 27 Apr 2023, 11:35 I lost that nut not so long ago, too. My 450 ft-lbs electric impact wrench failed me.
same here, bought a new nut and applied blue loctite. 2 yrs, fine so far, I do check it occasionally.
Blacklab467
Year and Model: 2007 xc 70
Been thanked: 264 times
Post by Blacklab467 »
Perhaps this is another good reason to not remove the crankshaft bolt and pulley when changing the timing belt.
2003 XC 70 (sold)
