Timing belt change
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Re: Timing belt change
Post by 5rivers »
This is as close as I can get the marks to line up when the crank shaft and cams are where they are supposed to be!
Good enough?
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
Has thanked: 1507 times
Been thanked: 3823 times
Yes!
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
*ding*
Fries are done.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Winner ! Winner! Winner!
1999 V70 GLT
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
That's more like it.
(*As long as the slots machined in the rear [drivers side] of the cams are aligned as depicted in Roberts' video.)
5rivers
Post by 5rivers »
The car started with no problem but there’s a ticking noise that is evident. No such sound before removing timing and serpentine belts. Any idea what this could be? Attached a video.
IMG_0185.mov
(7.69 MiB) Downloaded 43 times
5rivers
Has thanked: 1853 times
Been thanked: 1714 times
If the car has been sitting for a while the lifters dry out. Normally a few runs and it will return to normal.
Keep revs below 3000 rpm but idle it around for 30 minutes to help those lifters pump up.
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Throw some Marvel's mystery oil in it, change oil as usual. It'll be consumed but it makes it easier for them to pump up and also removes some contaminates. Be warned, if you have sludge in that engine, it may dislodge some of it. *Mumbles about W engines to self w/sludging*
