Timing belt change
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Timing belt change
Post by 5rivers »
Greetings everyone!
I am in the midst of changing the timing belt on my V70 and am unsure of the cam sprocket marks and alignment with the marks on the cover.
I have the marks on the crank pulley lined up but only one of the cam sprockets is aligned. The exhaust cam sprocket is off by a tooth, this after 4 maybe 5 revolutions of the crank pulley.
What should I do next so all the marks line up?
Appreciate your suggestions!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
Has thanked: 1507 times
Been thanked: 3822 times
Slip the belt off and move the pulley to align it with the marks on the cover. You can do this without disturbing the other belt path if you are careful
5rivers
Post by 5rivers »
Top pic is the intake cam - aligned well.
Bottom pic is the exhaust cam - off by a tooth.
These are the positions when the crank pulley is aligned properly.
5rivers
5rivers
Post by 5rivers »
When looking at the intake cam sprocket, it looks like the bolts were not lined where they were initially. Should I take the belt off and adjust that sprocket?
5rivers
5rivers
Post by 5rivers »
If I adjust the exhaust cam sprocket then the intake and crank pulley will remain aligned, correct?
5rivers
5rivers
Post by 5rivers »
HELP!!
5rivers
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Yes. As abscate stated, you can slip the belt off, turn the exhaust sprocket one tooth, and reinstall the belt.
1999 V70 GLT
I use a zip tie to hold the belt on the sprocket in place while I slip the belt off the other , then move it a notch.
Don’t forget to remove zip tie then turn engine through two crank revolutions and recheck timing marks.
5rivers
Post by 5rivers »
Ok, thanks! Will try that 👍
5rivers
rrres
Year and Model: 1999 v70XC
Has thanked: 10 times
Been thanked: 26 times
Post by rrres »
I don't know the solution but it does look like, as you've mentioned, that the intake (sprocket?) is the one that is off. I don't think you necessarily need the locking tool, but it might be worth it to look at the rear of the cams to make sure the notches are properly aligned before you install the belt. It might turn out that the intake sprocket is off.
By the way, double check the crank sprocket notch marks, which aren't precise. Check it against the embossed mark on the crank sprocket.
It's blowby
