I asked before, but it was mixed in with other questions so may have been missed. I know the US as far as I know did not have the 10V engine, but for anyone that does, do you know if it has hydraulic valve followers/tappets? From this Volvo drawing on a Canadian Volvo parts site it looks like it may be. AS I have never stripped an engine, let alone a hydraulic tappet version , can anyone tell me if this looks like one in the picture, part #22a:
https://www.volvovancouverparts.ca/a/Vo ... 67866.html
I think I have also confirmed the crank pulley nut is a 30mm socket required, been a while. I may want to turn the engine to check the timing belt has not jumped.
Thanks,
96 850 base - 10V head Topic is solved
- Has thanked: 2215 times
- Been thanked: 1853 times
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I think that all of these engines have hydraulic tappets 10 and 20v...even the smaller 4cyl ones in s/v40 from that time.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1613 times
- Been thanked: 4077 times
You can confirm by…misha wrote: 11 May 2023, 12:31 I think that all of these engines have hydraulic tappets 10 and 20v...even the smaller 4cyl ones in s/v40 from that time.
1 stuffing paper towels into your oil pan until the oil flow is clogged, then listening for the clicks, like I did…
Or
2 looking for the small mechanical shim ports on the top of the head like this ( picture to come)
Thanks guys. Really appreciate the info, but hopefully now not a concern. Water pump bearing looks to be the issue.
I was fairly sure the cars up to 98 had hydraulic lifters and solid after that. But still to confirm!
Hydraulic to solid was a mid 1999 model year change , checked by engine number. Everyone of my four 99s happen to be hydraulicscot850 wrote: 12 May 2023, 08:30 Thanks guys. Really appreciate the info, but hopefully now not a concern. Water pump bearing looks to be the issue.
Jdawg to the rescue…
Post by j-dawg » 30 Jan 2017, 22:30
Lifters change from hydraulic to solid, and valve stems from 7mm to 6mm, at engine 1817653 for T5s. I think that's pretty far into the run - my Dec '98 T5 has engine s/n 15xxxxx.
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
From the startup sound my 10V made, I feel safe to say it was hydraulic
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 746 Views
- 2168 Views
Last post by SonicAdventure
- 2308 Views
Last post by Sommerfeldt
- 888 Views
Last post by Azik09
- 54 Replies
- 7708 Views
Last post by misha
