In case the car really needs help with front camber -
https://www.rockauto.com/en/moreinfo.ph ... 16&jsn=400
Available from others too, obviously.
Those rear links are tough to tackle; heat and a special tool are the only method I know of. Dr. Abscate may be able to shed more light, and Robert has done a few. Given the care the car seems to have been given by the previous owner, it would be unusual to find a problem there.
Causes wear to front tire inner shoulders?
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
The delta links aren't for the faint of heart. I gave up and sent it to a professional. Quoted $500, took 16+ billable hours and he really wished he'd have quoted $1600. It's not a fun time. So I wouldn't replace unless they are observably sloppy, ie you can shift the rear axle around bare handed.
Knows enough to be dangerous
- Been thanked: 4068 times
There are couple of subtle tricks to getting frozen delta links out, like drilling them or burning them out with oxy and enjoying a hot dripping burning rubber bath
- foggydogg
Roberts' buddy Dan in MI just did it on a C70 subframe he's putting under an R.
Not the most polished presentation, but he eventually figures out how to use the tool.
- 1459 Views
Last post by oragex
- 12 Replies
- 4363 Views
Last post by lous_97_850
- 872 Views
Last post by - Pete -
- 11 Replies
- 2545 Views
Last post by icrashcars
- 1375 Views
