1997 Volvo 850 GLT Turbo - very small hose above lower radiator hose in engine bay is broken.
moses3
Year and Model: 1997 850 GLT
Has thanked: 68 times
Been thanked: 5 times
Re: 1997 Volvo 850 GLT Turbo - very small hose above lower radiator hose in engine bay is broken.
Post by moses3 »
jreed wrote: 30 May 2023, 05:40 I had that concern too -- flexible thick wall silicone tubing worked. You can get a tight seal on the narrow end and still be able to stretch the tube over the larger fitting on the other side.
Nice. Thank you! You don't happen to know which size I need? Or maybe where did you get yours from?
Has thanked: 1505 times
Been thanked: 3818 times
Dorman makes a replacement rubber piece for this
https://www.amazon.com/Dorman-Help-4740 ... 146&sr=8-5
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
moses3 wrote: 30 May 2023, 07:01
No idea on the size, but there are vendors on ebay selling various sizes of silicon hose by the foot. Also IPD sells it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
4 or 5 mm hose should work. I have both, but can't remember which I used most commonly. Measure the outer diam. of the line, substract 1mm and use that as hose ID and you should be fine.
850 T5-R '95 auto Image
moses3
Post by moses3 »
hausmeister wrote: 31 May 2023, 14:28 4 or 5 mm hose should work. I have both, but can't remember which I used most commonly. Measure the outer diam. of the line, substract 1mm and use that as hose ID and you should be fine.
Thank you, I already tried 5 and it's too big, I believe it's actually 3.5mm ID. It was a BMW hose size used by various automakers in the 80s & 90s. I imagine 4mm might also work.
hausmeister
Might be that It was 3 & 4 mm, my bad.
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I used some 3.5mm or 4mm silicone hose from Verocious motorsports.
https://www.verociousmotorsports.com/Sh ... y-the-foot
