Has thanked: 1850 times
Been thanked: 1711 times
My buddy recently swapped his backrest cover on his 850 for one from a passenger side. Only real issue is the lumber support knob that comes out the opposite side, so you have to make one on the other side and have a hole on the other one. If you are really particular, you might be able to get an upholsterer to either patch it or swap it over from the original seat cover.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
I did nothing to my Volvo today, I just drive it. It runs really well at the moment, engine is silky smooth, new tires improved the ride a lot.
But I do have an issue with the windshield washers. They come on delayed, I replaced the small 3way valve under the hood, but it still feels delayed. I took the old valve apart and there was a piece of "something" stuck in it, after removal it seems to work again. There should be a filter in the line somewhere right? Maybe I need to clean the system
850 T5-R '95 auto Image
Has thanked: 1505 times
Been thanked: 3818 times
scot850 wrote: 22 Jun 2023, 19:09 My buddy recently swapped his backrest cover on his 850 for one from a passenger side. Only real issue is the lumber support knob that comes out the opposite side, so you have to make one on the other side and have a hole on the other one. If you are really particular, you might be able to get an upholsterer to either patch it or swap it over from the original seat cover.
I still have spare material in charcoal or beige to cover that hole, for a postage stamp
viewtopic.php?t=84734&start=40
Blew the repaired fuel hose off the junction from the fuel filter...again....
Thanked Kat for taking me 140 miles to Manhattan and back , then failing hose 1/4 mile from garage. Walked home, got P2, got bagels, put in toaster, went back and hard-towed Kat back home
Roughed up NiCopp line, JB weld, and double FI clamped it this time like others. tight access. Used old radiator hose to chafe relief the clamps on the fuel filler neck.
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Someone had a thread here where they swapped right to left seat covers. They cut a piece off the bad seat cover and stitched or glued it inside under the lumbar hole. Looked much better than a beat up seat cover.
abscate wrote: 23 Jun 2023, 08:45 Blew the repaired fuel hose off the junction from the fuel filter...again....
Did it fail both times 1/4 mile from your house after drives to Manhattan? That's a lot of karma you have banked up.
FireFox31
Once 1/4 mile and once 3 miles.
My Karma cup doth run over
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Some people are just REALLY LUCKY like that.
(other people are suspicious of all that luck)
volvolugnutr
Wish I could get good bagels here. All we have are stale Bimbo Bakery things that are called bagels.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
A REALLY good bagel place opened probably 6 months ago 5 minutes down the road from me. Fortunately we have a lot of NY transplants down here who know how to make bagels and pizza.
Not combined, of course!
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 327 times
Been thanked: 87 times
Post by CIK7 »
hausmeister wrote: 23 Jun 2023, 01:18 I did nothing to my Volvo today, I just drive it. It runs really well at the moment, engine is silky smooth, new tires improved the ride a lot.
I have a strange windshield wiper issue too. When I flick the wiper switch forward to rinse, it stays on until I pull the fuse. The first time this happened, the reservoir emptied itself before I could figure out that pulling the fuse was the only way to stop it.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
