I needed to swap the wiper fluid tank when I had the 99 s AWD parts car so I swapped the one off my car for the donor part. The bolt holes lined up but not all top-end stuff was the same. I have not had a working rear hatch wiper squirter since the swap. And the front wipers have gotten stuck on indefinitely anytime I use the pull-in wash stalk, meaning I have to pull out the fuse which is inconveniently also for the horn. I have brand new (not installed) front and rear wiper fluid pump motors but Id rather not install until I put in a new reservoir.
Who around here has a part number for the 1998 wiper fluid reservoir? Who has installed a universal tank? Who has a part number for the wiper fluid level sensor?
98 v70: wiper reservoir/tank and level sensor part number needed Topic is solved
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 2200 times
Link to Volvo website for your car. According to this any 98-00 wagon washer fluid tank should work. Needs to be a wagon as it has 2 pumps. One for front windshield washers and headlight washers and 2nd for rears. Rears is set higher so if fluid level gets low it stops sending water to rear in priority to front.
https://www.volvooftorontoparts.ca/a/Vo ... 76116.html
- CIK7
No wonder the donor part was different because it came from a sedan. I found what I needed. Thank you.scot850 wrote: 06 Jul 2023, 16:57 Link to Volvo website for your car. According to this any 98-00 wagon washer fluid tank should work. Needs to be a wagon as it has 2 pumps. One for front windshield washers and headlight washers and 2nd for rears. Rears is set higher so if fluid level gets low it stops sending water to rear in priority to front.
I hope it wasn’t too expensive. I understand things are dear in Antlers…
- CIK7
abscate wrote: 06 Jul 2023, 19:10 I hope it wasn’t too expensive. I understand things are dear in Antlers…
Should I add, 'Oh, deer, oh, deer......."
- CIK7
Dunno if yall ever play GTA V but I did a long time ago. Trevor Phillips says 'Oh dear, deer.' if he hits a deer.
- CIK7
I found the tank I needed on eBay. I hope the level sensor on the sedan tank fits in the wagon tank. It would suck if i have to wait until august 1st to order a $75 wiper fluid sensor.
- 13 Replies
- 7146 Views
Last post by Big Will
- 12 Replies
- 7169 Views
Last post by RickHaleParker
- 1984 Views
Last post by 93Regina
- 987 Views
- 587 Views
Last post by E Showell
