The ejector (transfer) 'pump' is really a pressure control system that works on residual fuel system pressure to move fuel from one side to the other. It has no pump motor. The other thing it has is a fuel level sensor that is linked the the fuel pump level sensor and the car averages the 2 levels to give a fuel level remaining in your whole tank.
Unfortunate new Volvo owner! (98 V70 AWD)
- Has thanked: 2200 times
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
Hello from a fellow '98 AWD owner! Good to see another interesting-color wagon brought back.
1. Replace the pump inside the basket with a Bosch or DW pump - no need for hackery. ProParts puts the pro in problem - they are crap and not to be trusted. Another member recently had the same issue with that ProParts pump getting super loud and continuously dying in his '98 R.
2. Blowby may be bad turbo seals or leaky valve stem seals. The factory PCV in these cars is decent, and there's no real need to mess with it. It may also just need to be driven.
3. Yep, they all sag eventually. I took the lower-the-front route as well, but keep in mind they'll likely try to work sometimes resulting in an inconsistent ride height, sometimes between sides, that makes it impossible to align properly. I'm currently saving up for actual suspension so I can get it aligned properly. If you want to keep stock ride height and bring the back up, check out the article I linked below - you can use S70 AWD stuff to replace the rear stuff without shelling out $800 for a pair of Nivos.
https://blog.fcpeuro.com/how-to-lower-a ... suspension
Enjoy the car! Here's a picture of mine
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
Tropic Green is rare and attractive but I'll always love Emerald Green the most. Fits right in next to the GUL and Sonics.
FireFox31
All th Volvo colours are gorgeous but the Emerald Green and Nautic Blue define class
abscate wrote: 07 Jul 2023, 03:10We can’t get them at all over here. Can you tell us how much they are? We might put together a group buy if you are willing?xanthefin wrote: 07 Jul 2023, 02:26I am able order new expanders. I guess in USA they not kept in stock.scot850 wrote: 06 Jul 2023, 22:59 If you are planning to fix the parking brakes at some point, DO NOT loose the expander and the little chamfered pin that holds it to the cable. Those are no longer available new!
Bag and tag!!
Should add that many further north would kill for a pair of rear brake dust plates in the condition yours are in. Again a long NLA item for AWD P80 cars.
Op- if you search my Kat Resurrection thread you will find a source for the OE fuel pump insert, which has to be built into the unique AWD cartridge .they are about $100 as of 2022
Quantum fuel systems
https://www.highflowfuel.com/
Genuine Walbro/TI Automotive GCA761-2 255LPH Fuel Pump Volvo XC70 1997-2007
WAL-GCA761-2-0009 2 $108.99 USD
Culito
- Been thanked: 7 times
Ordered that Walbro pump, thanks!
I reached under and the whole tank was vibrating - I don't think that'll last long.
I should have hinged that access panel!
Regarding blow-by - someday I'll do a compression check. Despite the PCV service, there seems to be a lot of oil making its way through the large hose to the PTC. No blue smoke and it runs fine, but the dipstick still shoots out smoke.
- V50M66
Walbro pumps are loud and not very reliable. Get a Bosch pump or DW200, do it right, and you won’t have to touch it again.
Classic!
Classic!
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
As I recall, Robert used a DW pump, but he wanted the volume for the tune he runs.Culito wrote: 08 Jul 2023, 10:18 Ordered that Walbro pump, thanks!
Some of the folks on swedespeed have had good luck with Walbro, but I haven't had that particular adventure on an AWD yet.
ProParts go in the same drawer with URO. Please don't put that stuff on your car.
- V50M66
I’ve read the opposite about Walbro - noisy, with a few reported early failures. I have a DW pump ready to go when I decide to do it on my AWD. I don’t make any more power than a stock T5, but everyone loves the DW pump so it’s worth it to get it instead of something people have had issues with, especially since it’s the same pricefoggydogg wrote: 08 Jul 2023, 21:47As I recall, Robert used a DW pump, but he wanted the volume for the tune he runs.Culito wrote: 08 Jul 2023, 10:18 Ordered that Walbro pump, thanks!
