P0442 code
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
P0442 code
Post by 02V70 »
My 2002 volvo v70 sometimes shows a message on the dashboard saying that the fuel filler cap is open or loose. Today, the check engine light turned on and gave the code P0442. According to Google, it signifies a small evap leak. I looked at my fuel cap, and noticed the o ring was cracked looking. Is this what is causing the problem? If not, what else can cause it, and how can I fix it?
Here is a photo of the cap.
2002 v70 X/C 288k miles
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 264 times
Post by Blacklab467 »
I would start by buying and installing a new gas cap o-ring. That may solve your problem, regardless your's is in need of replacement.
2003 XC 70 (sold)
Has thanked: 1855 times
Been thanked: 1714 times
+1 on that suggestion. That will cause the code, but even if it isn't it is long overdue having the seal ring replaced.
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
If I recall right I got a aftermarket cap and simply swapped the ring. That ring is way, way past it.
08 C702.5T (sold)
The non-Swedes:
