My 2002 volvo v70 sometimes shows a message on the dashboard saying that the fuel filler cap is open or loose. Today, the check engine light turned on and gave the code P0442. According to Google, it signifies a small evap leak. I looked at my fuel cap, and noticed the o ring was cracked looking. Is this what is causing the problem? If not, what else can cause it, and how can I fix it?
Here is a photo of the cap.
P0442 code
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 264 times
I would start by buying and installing a new gas cap o-ring. That may solve your problem, regardless your's is in need of replacement.
2003 XC 70 (sold)
- Has thanked: 1855 times
- Been thanked: 1714 times
+1 on that suggestion. That will cause the code, but even if it isn't it is long overdue having the seal ring replaced.
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
If I recall right I got a aftermarket cap and simply swapped the ring. That ring is way, way past it.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 1042 Views
Last post by neworleans
- 938 Views
Last post by joe_pinehill
