What do you think about installing a used coolant pump with some light surface rust on its fins? The pic shows the worst fins before cleaning.
The pump is from my old V70, Aisin brand, maybe 130k miles on it since ~2010. I did a bad job storing it, allowing that rust (and on the 20k mile idler and tensioner). I tried scraping it off with a screwdriver behind a wet rag, did a decent job, but still some deeper rust remains.
Is it safe to install this or smarter to spend the $88 on a new Aisin?
Install rusty but good coolant pump?
- FireFox31
- Has thanked: 158 times
- Been thanked: 300 times
- PXL_20230723_175708873.jpg (294.53 KiB) Viewed 385 times
FireFox31
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
For $88 not a chance. If it goes bad chance you could lose an engine. Just replaced my kids 02 S60 2.4T at 188k—mechanic said I almost lost the timing belt had it gone much further.
Now if $288 or more I’d maybe have a different opinion. But with 130k on it IMO not worth the chance.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 930 times
- Been thanked: 1004 times
I agree. Not worth the risk.
- Has thanked: 1855 times
- Been thanked: 1717 times
I also agree on it is not worth the time, effort or risk fitting it. Also it may be my imagination, but a couple of the impeller blades look bent.
At that price fit a new one and sleep easier. The tensioner and idler, you have to make the call. With 20k on them they should be good, but bad storage and potential for internal condensation/rust may make the call for you.
- FireFox31
Thanks for the input. My first and only timing belt job was an unthinkably long task (due to constant slight problems, hopefully all lessons learned not to be repeated). I don't want to do it more times than I have to.
Kicking myself for storing these in an unconditioned space for 1.5 years. It would have been nice to reuse the 20k mile tensioner and idler. If I won't use new ones which got wet with coolant, I can't use ones which may have internal rust.
abscate, do you want the parts back? Sorry I wrecked them.
FireFox31
- Has thanked: 1508 times
- Been thanked: 3827 times
No, thanks,FF..I would also not use a 130k pump unless it was for one of my own low use cars
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
The rust doesn't bother me. I'd be more concerned with bearing and seal condition. At 130,000 miles, it's life is probably limited. I'd re-use it if strapped for cash, with the understanding that I'd need to keep an eye on it, and be prepared to go back in an replace it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
For me the economy of that would fail as, on top of the worry, the four hours @ $25 self mechanic rate is more than a new OE pump454cid wrote: ↑24 Jul 2023, 09:33 The rust doesn't bother me. I'd be more concerned with bearing and seal condition. At 130,000 miles, it's life is probably limited. I'd re-use it if strapped for cash, with the understanding that I'd need to keep an eye on it, and be prepared to go back in an replace it.
Agreed, that is the same way I look at it. I will occasionally make a diversion on that path if for example a part is on back order and I need the vehicle. I still maintain that the vanes on the pump look strange on the RHS of the picture, like they are bent downwards.
The 2nd part is the potential for catastrophic failure and then the recovery cost of that repair.
- FireFox31
Thanks, it's that kind of math which helps drive better decisions. The pump will go in the scrap metal bin.
Are you all worried about potential rust inside the bearings? My first concern was rust on the fins contaminating the coolant and harming the engine internals.
FireFox31
- 1073 Views
Last post by Greg Sands
- 4287 Views
Last post by 93Regina
