Late 1998 V70XC driveshaft removal
Has thanked: 1505 times
Been thanked: 3818 times
Re: Late 1998 V70XC driveshaft removal
Pick, solvent , nylon brush
Repeat
Repeat
Now measure the depth of the hex head , mark your bit so you aren’t confident it’s locked in tight, you KNOW it’s in all the way
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
One trick I use for removing stubborn torx and Allen screws is to put valve lapping compound (a paste of oil and aluminum oxide abrasive) on the driver bit. Also sharpening the bit with a bench grinder right before using it.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
Everything back together, still have my clicking issue. When I hit the gas or brake, I get a short clicking pinging noise that sounds like the front of the car. I was so confident that it was the driveshaft CV after seeing the tear in the boot. I did rebuild the passenger CV axle 5000 miles ago, which I may have done incorrectly, but from what I read it seems like an axle CV problem would be a continuous clicking noise.
My next thought is possibly a strut mount/strut bearing issue....
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
jsrnsis
Post by jsrnsis »
Well, the problen turned out to be much simpler than tearing my driveshaft out.
My aftermarket firewall upper torque mount was too short, causing the bolt to not line up correctly between the torque arm and the forward bushing. Whenever the engine would shift, like changing gear, or my foot going onto or off of the accelerator pedal, the bolt would rattle against the front of the slot in the torque arm.
So to anyone reading this, before you go messing with your axles, driveshaft, or any suspension components, give that top torque mount a good look. I tested it by removing the nut and bolt that goes through the bushing and re-creating the conditions that would cause the clicking and popping.
Front driveshaft CV needed changing anyways, the grease was definitely cooked and the boot torn.
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
