Last picture. Bad humorbmdubya1198 wrote: 28 Aug 2023, 19:11Are the cams rotated 180 degrees?abscate wrote: 28 Aug 2023, 18:33 Got head on Elizabeth , did quick cam cover and belt but she runs funny. Air is sucked into the tailpipe and exhaust comes out of air cleaner
I’m baffled
( beautiful aluminum art)
- Has thanked: 1611 times
- Been thanked: 4074 times
- Has thanked: 316 times
- Been thanked: 531 times
abscate wrote: 28 Aug 2023, 19:41Last picture. Bad humorbmdubya1198 wrote: 28 Aug 2023, 19:11Are the cams rotated 180 degrees?abscate wrote: 28 Aug 2023, 18:33 Got head on Elizabeth , did quick cam cover and belt but she runs funny. Air is sucked into the tailpipe and exhaust comes out of air cleaner
I’m baffled
- Has thanked: 2210 times
You are clearly an ejit Abscate!
I owed you that one............!
Spent last hour chatting with a very nice young guy who is a former colleague of my mechanic buddy. He is an apprentice at the local dealer and drives a 98 S70 T5. Car looks clean except one door with rust in it. Weird.
He left a happy guy with an S70 trunk spoiler with a high level brake light built in. He has a plain version on his car now but really prefers the brake light version for safety/visibility. He has been looking for one for ages and I happened on this on in the junkyard last week, and best thing is it is the correct color!
Bonus is he does not need the mounting brackets so I'll keep them for now until he confirms his own are good. After that they will go in the 'unobtanium' pile in the stash for anyone else that needs them. I am hoping to also get a 2nd set of brackets one half of which needs a slight repair. Now just have to decide if I keep the 'standard' sedan trunk spoiler as I potentially have good brackets for it, or take just the spoiler back to the yard for credit? Decisions, decisions!!
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
Clearly you can see that the engine is installed backward. Remove, rotate, reinstall. Easy, right?abscate wrote: 28 Aug 2023, 18:33 Got head on Elizabeth , did quick cam cover and belt but she runs funny. Air is sucked into the tailpipe and exhaust comes out of air cleaner
Keep it in case someone needs it. Those spoilers are tough to find. Besides, it's currently adding +10 HP to your parts stash.scot850 wrote: 28 Aug 2023, 20:16 Now just have to decide if I keep the 'standard' sedan trunk spoiler as I potentially have good brackets for it, or take just the spoiler back to the yard for credit? Decisions, decisions!!
I just bought a nice used tailgate for Geronimo. It's from a GLT and had a spoiler at one point, but it was gone when I got it. Now I want to obtain a V70 spoiler for the T5M. So silly and useless, but a tasteful OEM "upgrade" like many other little things done by the previous owner of that car.
FireFox31
The spoilers look great on the wagons (sedans too, for that matter!) even if they're useless. I still need to paint match mine!FireFox31 wrote: 29 Aug 2023, 11:33 I just bought a nice used tailgate for Geronimo. It's from a GLT and had a spoiler at one point, but it was gone when I got it. Now I want to obtain a V70 spoiler for the T5M. So silly and useless, but a tasteful OEM "upgrade" like many other little things done by the previous owner of that car.
…and Elizabeth progresses….one really good hour+ today
Dipped lifters into a cap of oil then dropped into place.
Make sure plug holes are paper plugged
Dab and prep both cover sides to Barbie pink with Permatex and foam roller
Install cams , exhaust notch down, intake up
Lube cam thrust bearing with grease
Confirm crank mark
Install spark plug orings
Install cam cover
Bring down cam cover with cylinder 2,4 bolts …4 each cylinder
Install rest of cylinder bolts
Do rear side
Do front side
Confirm cams rotate with reasonable force
Confirm crank mark
Install cam cover
Do rear side
Do front side
That is not the correct 'eggcrate' grille!
Well remembering how the challenge was last time with the binding cam issue, you clearly learned the tricks for this time! Long may it continue!
Firefox, hate to say it, but I have a wagon tailgate spoiler, but more importantly the NLA mounts. Unfortunately a little scraped and in white!
I may keep the sedan one, not decided yet!
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Getting ready to smoke up the neighborhood.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Abscate, when installing the cams and cam cover, do you try and seat the cam seals during assembly or leave them loose and tap them in after the cover is bolted down?
