2005 V70 2.5T front end issues (CV or suspension?) and engine diagnosis
RoVolvo
Year and Model: 2005 V70 2.5T
Post by RoVolvo »
I’ve been working my way through the an assortment of issues with my V70. It has 208k miles, so it had a lot of issues to look into. So far replaced the front struts/shocks with bilstein kit, rear shocks. Had control arms and end links. New tires, new brake pads. Replaced a lot of the hoses for the brake vacuum line and the vacuum switch. Serpentine belt, compressor, coil covers and spark plugs, flushed transmission several times and changed oil, oil filter, cleaned and replaced throttle body, replaced engine vacuum hose (cracked), and
Right now I know the mounts need to be done, and that’s my next project. 2 issues I wanted advice on, particularly while I have the car lifted and wheels off to install new tie rods. Right after I had new struts and shocks put in, car felt like new again. I then went on a road trip and was driving through Michigan and hit a pot hole. It bent the right rear wheel. I was able to get the wheel repaired, but it became clear that tie rods went from “on my list” to “urgently replace” (some vibrations, steering felt a little loose, an occasional clunk when turning). I did CV test (driving backwards in tight circles) and didn’t hear anything, pull out if parking lot on a tighter turn with slope to flat, and I hear a clear ka-chunk. I took wheel off and could move the tie rod with my hand back and forth, so that was that. After a miserable time getting the old tie rods off, it was clear they were in bad shape. Once I get them off. While they are off I’m moving the wheel back and forth and it has a weird feel to it and, kinda (not smooth) and a weird sound.
IMG_9040.MOV
(14.71 MiB) Downloaded 78 times
Is my cv joint the issue here? Did my mechanic maybe mess up the strut install?
Other issue: I feel like mileage, engine power and sound has degraded a bit over the last year. It dropped precipitously, had it looked at and they found a cracked vacuum hose and replaced it. Started improving but then started to get worse again. Changed spark plugs and coil covers and it sounded better right after, but then slowly sounds worse again. Sounds better after cleaning throttle, but slowly sounds worse again. I thought it might PCV, but it passes glove test with flying colors. I had my mechanic take a look and he thought pcv was fine, also checked the crank seal. He said my engine has better pressure/seal than his 2017 Nissan truck. I have noticed some black residue on the turbo which maybe there’s an issue around there? I’m getting absolutely no fault codes of any kind. So I just don’t know what to think. I took video of the turbo from underneath. I thought maybe it could be exhaust, but i don’t seen anything obviously wrong with it and neither did my mechanic.
IMG_8971.MOV
(64.99 MiB) Downloaded 65 times
Anyway, any thoughts would be great. Thanks
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
When was the engine air filter last changed? Have you tried cleaning the maf with proper maf cleaner? I cant comment on suspension but my older wagon had a drop off in performance when someone forgot to change the engine air filter for a good long time :P
2008 S60 2.5T Auto (Sold)
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
dried up residue on the turbo could be running down from the charge pipe to turbo rubber coupler, they tend to get oily and weep.
ignore it unless the exhaust starts blowing blue smoke or you find oil drips beneath the car.
I suspect the strut top bearing for that chunky movement. Theres probably a simply test but I don't know what it is.
maybe loosen it slightly at the top and see if it changes, just guessing here.
Otherwise I'd start disconnecting components ,recheck for the rough movement, start with tie rod to knuckle, then cv joint to wheel hub.
At some point it will go away.
are you aware the upper 19mm bolt and nut are loose on the knuckle to strut mount .
if theres no codes and it gets you where you're going I'd just drive it, worry creates a lot of phantom "sounds bad".
RoVolvo
Post by RoVolvo »
yanga001 wrote: 07 Sep 2023, 10:16 When was the engine air filter last changed? Have you tried cleaning the maf with proper maf cleaner? I cant comment on suspension but my older wagon had a drop off in performance when someone forgot to change the engine air filter for a good long time :P
I’m not sure. It looks grey but no large amounts of debris or anything too bad. I just tried to get a new one, but it didn’t fit (same brand and model but it was too thick). I’ll try again.
RoVolvo
Post by RoVolvo »
jonesg wrote: 07 Sep 2023, 11:04 dried up residue on the turbo could be running down from the charge pipe to turbo rubber coupler, they tend to get oily and weep.
I’m not aware of said loose bolt. I’m generally concerned about the job the mechanic did on the strut (he didn’t notice the tie rods were shot, and when he did the control arms he didn’t notice the shocks were shot). The tie rods were the last straw for me so I guess I’ll have to find someone else.
As for no code, I think I’m just a little confused how my mileage could drop so far and not have something wrong. Maybe I’ll just have to keep waiting.
jonesg
Post by jonesg »
the loose bolt is critical to hold strut to knuckle, you can't drive it like that.
I'd agree you had a klutz of a mechanic.
to solve the mileage problem requires digging deeper , reading fuel trims are a good way.
RoVolvo
Post by RoVolvo »
jonesg wrote: 08 Sep 2023, 15:56 the loose bolt is critical to hold strut to knuckle, you can't drive it like that.
Okay, I took another look today when I did my engine mounts. I took pictures of the knuckles and let me know if you see something wrong there, I’m not sure I do.
I also took a video of the sound source, although it doesn’t quite capture it, but there is a creaking noise coming from the top of the strut at the mount. It’s on a lift there so I don’t fully understand how that would affect it, but the angle is questionable to me and they do not seem even. Idk what they did but there is something wrong.
IMG_9107.MOV
(22.93 MiB) Downloaded 46 times
Also super pissed since it is not the part I agreed to pay for (they put in preloaded duralast, which I would have done myself if that’s what I wanted). I also have a pic of it under load at the bottom.
Last a picture of the mount under load
Struts/shocks/springs are always something that scare me to work on so I know nothing about their proper installation but judging from other final products this seems very off to me. Happy for any input since I will be questioning my mechanic about it and I expect him to weasel his way out of any complaints.
jonesg
Post by jonesg »
the bolts appears to be tight in a clear photo, there was poor light in the first video.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 263 times
Post by Blacklab467 »
Maybe the strut bearings or spring seats are poor quality? Everything looks ok in your pictures. Can you hear anything when the car is on jack stands and you have someone turning the wheel back and forth? What brand are those strut/spring assemblies?
2003 XC 70 (sold)
RoVolvo
Post by RoVolvo »
Blacklab467 wrote: 10 Sep 2023, 21:07 Maybe the strut bearings or spring seats are poor quality? Everything looks ok in your pictures. Can you hear anything when the car is on jack stands and you have someone turning the wheel back and forth? What brand are those strut/spring assemblies?
On jack stands with wheels off, I get a weird creaking noise from the top of the struts. You can hear it in the video I posted
