2005 XC70 Front Suspension Noise/End Link replacement issues
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
farmer66
Year and Model: 2015 XC70; 1985 245
Post by farmer66 »
Hi All,
I just had my front sway bar end links replaced at a local shop, with whatever they deemed was the correct part from NAPA (I saw the NAPA guy deliver the replacements). Anyways, a week and a half later, and not more than 200 miles, my front end is making noise again, and this is the issue.
I had a shop replace the front struts with all new parts from IPD, including the sachs struts, HD spring seat, and the Lemforder upper strut mount. These parts have under 14,000 miles on them.
I'm looking for what could possibly cause this, before I call the shop tomorrow, as I believe everything on the strut assembly should be in good shape, and the only thing that has changed is the sway bar end links. I'm not sure how the end links could cause this, so if somebody could explain, I'm all ears. Thanks!
Magnus308
Year and Model: S60 2,5T 2005
Post by Magnus308 »
I dont see anything strange on those pictures :?:
Tonyx
Year and Model: 2001 XC70
Has thanked: 3 times
Been thanked: 8 times
Post by Tonyx »
The gap below strut top bushing and strut top bearing is normal. This gap allows quicker rebound response and lower suspension friction during steering maneuvers.
You may need to investigate further where the noise is coming from. If you can describe more specifically when and how the noise occur it may help the forum members to chime in.
One easy check is: with car parked and wheels straight, reach around each wheel and try to rotate the sway bar end links. They should be fairly hard to rotate, all four of them.
2003 XC70 230K and counting..,
farmer66
Post by farmer66 »
That's a normal gap? I've never seen it before on this car, or when I had my '98 XC.
The noise is very similar in occurrence to when the shop determined the end links were bad, the only difference is this noise is sharper and possibly louder.
farmer66
Post by farmer66 »
Ok, I just drove to work, and I'm able to reliably create the noise with a quick back and forth swerve. Still has the clunking sound like the old end links had, but it is a little sharper, and appears to be mostly on the drivers side.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
Try disconnecting the end link at the lower attach point. Then drive the car and see if it's quieter. (You can wire the end link out of the way if needed so that it doesn't contact anything while doing the test drive.)
Tonyx
Post by Tonyx »
farmer66 wrote:That's a normal gap? I've never seen it before on this car, or when I had my '98 XC.
When the car is up on a lift and the wheels are unloaded you will not see the gap. It's basically the force of gas charge in the strut bearing up on the strut top mount and pushing against the middle bushing part.
My gut feels is that your top cross brace wasn't torqued down properly and causing sharper noise. Either way, why not have the repair shop check it out for you?
farmer66
Post by farmer66 »
I brought it back to the shop yesterday, turns out they just had to reseat the lower part of the endlink(s), I'm not sure if it was just one side or both.
Anyways, the original reason for this post was that gap, as I had never seen it before, and initially thought that was the reason for the noise.
Thanks for your input!
