bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
SOURDOUGHJIM wrote: 04 Oct 2023, 06:36 '04 V70 LH low beam burned out. Bulb connector toast. Green wire terminal still OK. Black wire terminal not OK. Crimped on an insulated spade connector. Connected both to new bulb, Hella H7LL. Ordered a high heat connector from RockAuto. Any suggestions on bulbs that produce less heat and won't trigger the bulb failure warning? (I rarely drive at night.)
LEDs would produce less heat, but that would trigger the bulb warning. I think your best option would be to use a high heat rated connector, and if you don't need them turn off the DRLs.
SOURDOUGHJIM
Year and Model: 2004 V70 2.4
Has thanked: 53 times
Been thanked: 27 times
Post by SOURDOUGHJIM »
Does turning off DRL's involve some computer voodoo or a simpler way?
bmdubya1198
SOURDOUGHJIM wrote: 04 Oct 2023, 08:58 Does turning off DRL's involve some computer voodoo or a simpler way?
I think VIDA is required unfortunately.
Has thanked: 1848 times
Been thanked: 1710 times
The headlight switch has a small screw on the front (it is hidden) or on the back of the unit. Don't recall having to use Vida for that.
On an 850, this is Robert's video on the subject. Up here I have not seen that screw as I don't think we have that option. On the back at the top of the light switch there is a small white slider that does that as well.
bmdubya1198
scot850 wrote: 04 Oct 2023, 15:39 The headlight switch has a small screw on the front (it is hidden) or on the back of the unit. Don't recall having to use Vida for that.
He has a P2, which doesn't have that switch.
OK. Wrong section. There is a P2 video on Youtube. That shows a computer to switch off:
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
My 850 had the screw on the switch, the V70 needs diagnostics to turn off
There are several methods on Vida depending on year model, this is for the facelift cars
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Has thanked: 1505 times
Been thanked: 3818 times
In P80 platform there are variations across markets amd even regions. I believe US gets the DRl switch on front plate,( actually technically, rear of switch, visible to driver) Canada gets it hidden switch under dash
P2 is all VIDA driven
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
bmdubya1198 wrote: 04 Oct 2023, 14:04
A good scanner is required. I am able to do it with a foxwell scanner with the Volvo liscense. Does not require a software load or purchase, it’s just a configuration switch. A dealership should only charge you for the time to do it.
2008 S60 2.5T Auto (Sold)
