LEDs would produce less heat, but that would trigger the bulb warning. I think your best option would be to use a high heat rated connector, and if you don't need them turn off the DRLs.SOURDOUGHJIM wrote: ↑04 Oct 2023, 06:36 '04 V70 LH low beam burned out. Bulb connector toast. Green wire terminal still OK. Black wire terminal not OK. Crimped on an insulated spade connector. Connected both to new bulb, Hella H7LL. Ordered a high heat connector from RockAuto. Any suggestions on bulbs that produce less heat and won't trigger the bulb failure warning? (I rarely drive at night.)
- Has thanked: 304 times
- Been thanked: 517 times
SOURDOUGHJIM
- Year and Model: 2004 V70 2.4
- Has thanked: 53 times
- Been thanked: 27 times
Does turning off DRL's involve some computer voodoo or a simpler way?
I think VIDA is required unfortunately.SOURDOUGHJIM wrote: ↑04 Oct 2023, 08:58 Does turning off DRL's involve some computer voodoo or a simpler way?
- Has thanked: 1847 times
- Been thanked: 1710 times
The headlight switch has a small screw on the front (it is hidden) or on the back of the unit. Don't recall having to use Vida for that.
On an 850, this is Robert's video on the subject. Up here I have not seen that screw as I don't think we have that option. On the back at the top of the light switch there is a small white slider that does that as well.
He has a P2, which doesn't have that switch.
OK. Wrong section. There is a P2 video on Youtube. That shows a computer to switch off:
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
My 850 had the screw on the switch, the V70 needs diagnostics to turn off
There are several methods on Vida depending on year model, this is for the facelift cars
- Has thanked: 1504 times
- Been thanked: 3817 times
In P80 platform there are variations across markets amd even regions. I believe US gets the DRl switch on front plate,( actually technically, rear of switch, visible to driver) Canada gets it hidden switch under dash
P2 is all VIDA driven
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
A good scanner is required. I am able to do it with a foxwell scanner with the Volvo liscense. Does not require a software load or purchase, it’s just a configuration switch. A dealership should only charge you for the time to do it.bmdubya1198 wrote: ↑04 Oct 2023, 14:04I think VIDA is required unfortunately.SOURDOUGHJIM wrote: ↑04 Oct 2023, 08:58 Does turning off DRL's involve some computer voodoo or a simpler way?
2008 S60 2.5T Auto (Sold)
