Oil Ooze from coolant tank - Oil Cooler bypassed :-(
twm
Year and Model: 2007 XC90 D5
Post by twm »
Hello to All
Newbie here - Love the xc90 but found oil in the expansion tank. I thought it was the cooler changed it and then bypassed it because I have the same issue.
Oil continuously floats out of the tank so obviously a leak somewhere, since I have the cooler bypassed I suppose it must be the head gasket??? - Unless there is another area oil can leak into coolant. When I did change the cooler I found an amount of coolant in the sump.
Any advice appreciated.
https://1drv.ms/v/s!Al_IUBrJS97YhtNw3_I ... A?e=jeZn8J
Regards to all
Terry
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Not quite so much oil but that was the first thing that came to mind :roll:. How did you bypass the cooler? Did you check the dipstick to see if the oil is milky?
