jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
MoVolvos wrote: 09 Nov 2023, 17:24
What did you use? The high temp chaulk I used did not dry all the way through so wasn't hard. I inserted some thick radiator hoses and filled with the high temp chaulk. Winded up oozing a little.
Though the hot glue was sufficiently hard it couldn't with stand the engine heat. Imagine if the glue stick could handle the heat. Two large sticks was sufficient to fill it.
I honestly couldn't tell you as it ended up exploding out the other end of the tube and I threw it away. It could have been silicone tile caulk or maybe gorilla glue construction adhesive. I do know that using polyurethane such as sikaflex used for windshield bonds works well, you just need a high ratio 26:1 caulk gun (normal cheap steel ones are 5:1-10:1 ratios). If you're doing anything involving steel you should also stay away from silicone, the guy who replaced my windshield told me it is acidic when curing and will etch into steel and cause it to rust under the silicone. He showed me some pictures of cars someone tried to use silicone sealant to attach the windshield and it ended up rusting away the entire windshield frames.
As to why I did it? Seeing how many parts have gone NLA or been backordered, or how the availability of aftermarket parts variety has dwindled gives me anxiety.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Many sealants are self vulcanizing and contain acetic acid. You can tell from the vinegar smell. Once at a work place, self vulcanizing sealant was used to seal a lid on a steel tank. Later all of the internals of the tank were found rusting.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
Took the 850 to the carwash, came home and mowed, which covered it in dust. Cleaned the windshield and then RainXed it. I found I have a aerosol can of RainX, while looking for my starting fluid for another project, so I decided to try it out. I'm going to do the same with the S70.
The other project is older Kohler generator I bought recently. It's been sitting for quite some time, but I suspect is low hours. It fired on starting fluid, and then ran for a few seconds on some 2-stroke mix I had in a bottle.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
Replaced the seized rear brakes in the Silver Bullet with new Pagid pads and rotors, as well as Cardone-refurbished calipers, which appeared to have a lightly applied gray-beige powder coating.
Rusty rear brakes
Rusty rear brakes
New rear brakes and caliper
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
The caliper looks good. I'm contemplating doing the same thing on my 97 850. How much trouble if any did you have loosening up the brake lines?
brunocerous
jreed wrote: 11 Nov 2023, 15:43 The caliper looks good. I'm contemplating doing the same thing on my 97 850. How much trouble if any did you have loosening up the brake lines?
I soaked them in PB Blaster well before starting, and one side loosen nicely. The other side seemed to bind after a couple of turns, so I ended up holding the brake line and turning the caliper off of it and the new one back on.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
brunocerous wrote: 11 Nov 2023, 15:14 Replaced the seized rear brakes in the Silver Bullet with new Pagid pads and rotors, as well as Cardone-refurbished calipers, which appeared to have a lightly applied gray-beige powder coating.
Don't spray the rotors with any brake cleaner just wipe with alcohol if needed. Many rotors now come with a break in coating while the remainder keeps it from rusting.
Has thanked: 1505 times
Been thanked: 3818 times
volvolugnut wrote: 11 Nov 2023, 08:43 Many sealants are self vulcanizing and contain acetic acid. You can tell from the vinegar smell. Once at a work place, self vulcanizing sealant was used to seal a lid on a steel tank. Later all of the internals of the tank were found rusting.
The steel corrodes, the sealant will live long and prosper….
Yesterday I had to pull the battery from the 1987 244 Volvo for use in the John Deere mower. While the hood was open, I added some oil to the sticky hood release and some WD-40 to the hood hinges. The grill is removed by two quarter turn clips. Checked the oil level. Admired the basic simplicity of the design that is now 36 years old.
Has thanked: 1848 times
Been thanked: 1710 times
It is funny you mention those twist clips for the 240 grille. While the never ending parts cataloguing of the smaller parts goes on, I came across one of those 240 grille clips. Considering I sold my last 240 around 1988, I have no idea why I have one of them still. Only other possibility is my parents had a 240 until about 2004? and I brought back some parts from my dad's house when he passed and maybe it was in there. Amazed myself that I recognized it after all these years!
