1999 s70 t5 banjo bolt which hole?
i4gotmyid
Year and Model: 2004 xc70
Post by i4gotmyid »
So...i'm an idiot, I removed the pcv breather hose (without photos) and am ready to reinstall it. I noticed there are two such holes to install it in, a lower and upper. The slotted guard on the hose seems to suggest the higher one, but there are marks on the lower that indicate the hose was previously there. If I try to put the hose on the lower, the guard pushes the hose away from making contact. I figured I would ask here and see as I dont want to have to do this twice and I dont have access to an already built engine.
1999 S70 Turbo ch-00353
Part # for hose 9470330
Has thanked: 1613 times
Been thanked: 4078 times
This is the coolant banjo off the PCV manifold that mounts on the rear of the cylinder head? I’ll snap a pic this morning
i4gotmyid
Post by i4gotmyid »
Yes! I would so appreciate that!
Well, not sure if picture helps. Let me try to scour archives , too.
rrres
Year and Model: 1999 v70XC
Has thanked: 12 times
Been thanked: 34 times
Post by rrres »
Flywheel Housing Port after removal of Crank position sensor and housing.jpg
The one with the coolant.
It's blowby
It looks like the banjo threads into the head and the heater hose right below it into the block?
Has thanked: 2215 times
Been thanked: 1853 times
I just checked also, but it is hard to see on a built up motor with the turbo. However, mine is plugged into the lower hole as Abscate says.
i4gotmyid
Post by i4gotmyid »
Thanks guys! Moving forward makes me feel accomplished
