03 S60 t5 awd
jboncher01
Year and Model: 1997 850 GLT
Has thanked: 3 times
Volvo Repair Database 03 S60 t5 awd
Post by jboncher01 »
So the power steering system is low/possibly empty. It has a bunch of fluid everywhere, I am trying to narrow down where it is coming out of. Do I have to use the chf11 fluid or can I use a cheaper alternative to find the leak and then flush the system after I have the leak fixed and fill with proper fluid? Thanks in advance.
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
chf 11s or chr202 would be good
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
jboncher01 wrote: 18 Dec 2023, 12:03 So the power steering system is low/possibly empty. It has a bunch of fluid everywhere, I am trying to narrow down where it is coming out of. Do I have to use the chf11 fluid or can I use a cheaper alternative to find the leak and then flush the system after I have the leak fixed and fill with proper fluid? Thanks in advance.
You will be fine with any DEX III compatible alternative for finding the leak. Today's automatic transmission fluids are better than back in the day. I've gone through 4 cases of Havoline using it both in the transmission and PWST without issue in many makes and models. It was much cheaper 3 to 4 years ago however. Used in Honda, Volvo, Nissan and Lexus.
