2002, V70 (ATF Drain) Topic is solved
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Post by Mr. Detail »
Hello Gentlemen and Happy New Year!
I want to change out my ATF but using the slower, less taxing method where you drain about 3.25 quarts from the
sump and then re-fill from the top dipstick with a funnel. I saw a video that stated to do this again after driving 1,000
miles. Do you think I can repeat this procedure a little sooner than that, say 500-750 miles since my daily commute
Is only 25 miles?
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
It's really all opinions. You'd already change a majority of the fluids only for the next round to be less than that. I only changed it once and never bothered doing another round.
I'd say you either do it back to back or whenever you get to it. Maybe just do it with your next oil change.
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
While you can do it earlier I’m with Chris that at the next oil change is easiest as you are already under the car with a drain pan and tools.
Now if it is really dirty and you want it done sooner I’d guess even with two or three drives to work it’ll be mixed up enough you could change again.
When I first bought my 08 S60 the ATF was dirty so I did the first change, second at 1000 miles and third at next oil change. Just did a fourth—20k since my last one and the fluid looks pretty good.
08 C702.5T (sold)
The non-Swedes:
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 175 times
Post by dikidera »
If the oil is very contaminated not even 30l will clear it out completely, I am speaking from experience.
Mr. Detail
dikidera, what is "30I"?
dikidera
Post by dikidera »
Sorry it is a habit to abbreviate liters. So yes 30 liters of ATF.
Krons
Post by Krons »
dikidera wrote: 02 Jan 2024, 23:42 If the oil is very contaminated not even 30l will clear it out completely, I am speaking from experience.
I’ve done two Volvo Aisin automatics via the transmission cooler return flush method and each took right at 12 quarts for the fluid to be pink and clear.
08 C702.5T (sold)
The non-Swedes:
dikidera
Post by dikidera »
My atf was very contaminated. The first time i ever did a drain and fill it was like used diesel oil. Pitch black
Pictures speak a thousand words don't they. The first picture is already at 6 or 7l drain I ever did.
The last picture is after 30l(31 quarts). Better but not fully.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Looks like your torque converter clutch is gone, dikidera.
vtl
Post by vtl »
Mr. Detail wrote: 02 Jan 2024, 10:23 Hello Gentlemen and Happy New Year!
Is only 25 miles?
You can do it as soon as the torque converter had a few minutes to properly mix old and new fluids. Doing more than one d&f close to each other makes sense totally. Mileage does not matter for ATF contamination, it's mainly a linear function of how many gear shifts the transmission served in that period.
