- Has thanked: 2215 times
- Been thanked: 1853 times
Didekera - sorry to hear there may be a HG issue again. Hopefully it is not or is old oil from previous issue.
On the suspension issue. Been quite a while since I last did a P2 front suspension. If you replaced the lower control arm, I believe I recall, like the P80's you should not torque the control arm bolts until the weight is on the suspension or you can damage the bushes.
I may be wrong, so maybe someone who has done this recently can confirm?
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Well if we go through the process of elimination, I am very curious where the oil feed line is to the head. Is it just one port?
I read somewhere that because the oil port is so far away most of the time the issue from a HG is just exhaust gasses in coolant and less likely for oil unless the oil cooler fails.
Of course a cracked head can also do that, however before the head was machined it was checked for cracks and it was fine.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
its because cyl compression is a lot higher than coolant pressure.dikidera wrote: 07 Jan 2024, 15:51
Coolant can enter the chamber only after shut down.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
It's not head and usually not a gasket. 2.4T eventually blows gasket, since it is not a MLS gasket, but a good one lasts 10+ years.dikidera wrote: 07 Jan 2024, 15:51 Well if we go through the process of elimination, I am very curious where the oil feed line is to the head. Is it just one port?
I would inspect cylinder block: measure bores in upper end, look for sleeve separation, measure straightness. Also the cylinder head need to be machined. It develops depressions between fire chamber and coolant passages, which weakens the gasket a lot.
Anyways, there's a list of must-do things that needs to be done when cylinder head comes off. If you did a sloppy job it will bounce back.
dikidera
It was machined, by 0,14mm. The block had 0,06 yo 0,07mm of warpage on cylinder 1,2 on the exhaust side, diagonally the most. Sleeves were not measured. The new headgasket was Elring but not MLS. Yeah the block was not super straight, but I did not have the tools such as en engine hoist to get it out and have it machined so I just went with the head.
The head was torqued with new head bolts, however in the last step instead of 130 degrees, we decided to torque it to 150. In the end if she decided to blow again I likely would get a different engine rather than this one.
vtl
Did you coat the new bolts with oil or (better) fastener assembly lubricant?dikidera wrote: 10 Jan 2024, 06:57 It was machined, by 0,14mm. The block had 0,06 yo 0,07mm of warpage on cylinder 1,2 on the exhaust side, diagonally the most. Sleeves were not measured. The new headgasket was Elring but not MLS. Yeah the block was not super straight, but I did not have the tools such as en engine hoist to get it out and have it machined so I just went with the head.
SOURDOUGHJIM
- Year and Model: 2004 V70 2.4
- Has thanked: 55 times
- Been thanked: 28 times
Yesterday's drive from SE Missouri to So. Indiana I got 31.6 mpg. I do very little city driving so my low is 27-28 mpg combined city and highway.weitau wrote: 03 Jan 2024, 21:43 Yes, I agree it has to be under ideal conditions. The best I could get before was 32 MPG going south on I95 in the Carolinas a year earlier. I don't remember, but I probably was using mid-grade 89 octane and kept it at 60mph (not realistic agreed). I don't have a turbo, FWD, and I'm on skinny, stock tires 215/55R-16.
In city driving, my wife gets 19.3 mpg avg, but I can get over 20. A lot has to do with your driving habits such as frequent short trips vs highway, etc. Once I get my thermostat fixed, my city driving should improve.
I added about a quart of -35 washer fluid in prep for next week's chill.
- 12198 Replies
- 1680175 Views
Last post by RedBrickCollector
- 97 Replies
- 209800 Views
Last post by br0dy519
- 59 Replies
- 61662 Views
Last post by smacknab
- 6976 Views
Last post by xHeart
- 12219 Views
