help please....
on the way to work had this going on.
also, how do I message a moderator, my phone couldn't post messages, strange.
thoughts?
Al
rough starting....
revs to 3000 rpm
runs but when I hit the throttle it will stumble
shut off, added gas tank drygas ...two bottles
it's 22 degrees F this morning
limping to work....hopefully get there
just did the coolant sensor
fuel filter done last year
next?
Crank position sensor?
fuel pressure regulator?
1998 v70 stalling issue
- Has thanked: 1506 times
- Been thanked: 3818 times
Are you stage 0 on cap rotor plugs and wires ?
Ignition parts are the first point of failure in cold weather
surfbug1
- Year and Model: 1998 V70, 2006 S80
- Has thanked: 41 times
- Been thanked: 9 times
yes, just got that done in the last 2 months
Al
will report in on how it is running later this eve, I work till 7 pm EST
Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
Ping me!
surfbug1
after adding the drygas stuff ...seems to be running better
will keep all of ya updated!
Al
Al
Ping me!
Ping me!
surfbug1
this stuff
is this basically rubbing alcohol? for 2$?
could I went to CVS , and thrown that in? lol
the heet stuff was 7$ for two bottles ....
well at least it's working for now!
- heet
- IMG_20240118_085432.jpg (263.88 KiB) Viewed 359 times
Ping me!
Ping me!
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
I think the yellow HEET is methanol based and the red HEET is isopropanol (rubbing alcohol) based. My memory is that they are pure or nearly pure alcohol. From what I've seen, the rubbing alcohol in the stores usually already contains 10% to 30% water.
- Has thanked: 1850 times
- Been thanked: 1712 times
If this has helped, it could be a case of your filled the car with some bad gas possibly with water in it. Water tends to sink to the lowest point in the tank so will get drawn through first or tend to freeze in cold weather giving poor starting and running.
Hopefully this gets you over this issue. It gets expensive quickly filling it with that stuff!
surfbug1
hey Canada! we are at 17 degrees! balmy compared to your -30 lolscot850 wrote: ↑20 Jan 2024, 08:22 If this has helped, it could be a case of your filled the car with some bad gas possibly with water in it. Water tends to sink to the lowest point in the tank so will get drawn through first or tend to freeze in cold weather giving poor starting and running.
yeah man, I will add some more heet---- and also fill with 93 octane another time....and stay away from the junky gass stations
maybe I will put some SEAFOAM in the tank as well
anything else I could toss in there?!?! some Kool Aide?
/lolz
big Al
Ping me!
Ping me!
surfbug1
ran around today, no stalling. 4 or 5 different start stops ...10 miles total.
maybe the gas additives worked.....will keep you guys updated!
Ping me!
Ping me!
Fingers crossed it was either dirty injectors or bad gas that has now gotten out of the system. Here's hoping!
- 9 Replies
- 7047 Views
Last post by enriquepr21
- 1500 Views
Last post by jjs70pdx
