Idle control valve?
Cvovo7
- Year and Model: 1996 Volvo 850 GLT
- Has thanked: 6 times
Idle control valve?
Hello, I just bought a 96 850 glt and it will start but won't stay running. I pulled the idle control valve and cleaned it. Still same thing. Plugs n wires were swapped also. Maybe MAF sensor??? Any help is appreciated. Clean car 160k
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 22 times
Replace every vacuum line on the car, preferably with silicone. I do this to every new to me 850. Chances it solves the problem may be as high as 50-50. If it does not, you will have solved a future one for sure.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
Cvovo7
I'll definitely look into it. Thanks a lot. The thing is car was running fine. Sometimes it will take about 10 times trying to start then it would idle and purr like a kitten. Now it just won't stay running. Maybe a fuel pump also? Plugs are about a year old but car sat in my driveway for a while. No wear and tear on them.
- Has thanked: 1843 times
- Been thanked: 1710 times
The ECT (coolant temp sensor) and the iAC both act like chokes to richen or not the amount of air and fuel going into the engine when cold.
Do you still get the same issue if the car only sits for maybe 20 minutes or so?
Fuel pressure should be 40-43 psi when running. This can be checked at the Schraeder valve on the fuel rail. The guys have already covered the other issues.
You may have cleaned the iAC but is it working? Can you hear it clicking when you turn the ignition on. Probably easier to hear with your ear closer to is and have someone else switch the ignition on so you may be able to hear it.
It is possible to damage the iAC by over cleaning it and to make it stick as I found out. I used a 9V battery with short cables taped to it to test it. +ve connection to the middle pin and ground/-ve to either of the outer pins.
Good Luck!
Good Luck!
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
if you unplug the MAF sensor and the problem is gone, it's your MAF. If not, likely vacum or ignition.
Especially the hoses close to the Turbo are tough to check for cracks.
The fuel pump or (fuel pump relay) - from my sample size of 3 850ies experience - usually works or it doesn't at all.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
