Checking the transmission fluid
- Been thanked: 504 times
The book says checking ATF with engine running, and hot.
I have now moved away from that myself and check with engine off and cold in the morning.
Info in forum.
Info in forum.
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 18 times
- Been thanked: 33 times
I always pull the stick out first, while the engine is running and clean it really good, so there's no trace of oil. Then reinsert it for about two seconds or so, remove it and look for the oil line on your dry dip stick.
Its a pain to do it and get an accurate reading. I also have a spot nearby at a township building where I can check it on a perfectly flat surface.
Really clean the dip stick good before getting your final reading.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
- 868 Views
Last post by difflock54
- 3336 Views
Last post by pmondrian
- 9 Replies
- 1501 Views
- 1812 Views
Last post by jacklyn51
- 837 Views
Last post by Ozark Lee
