V8 in a P3 XC wagon??
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Just ran across this IPD project car. Hmmm..
Can they do this because one of the XC90 V8 chassis's is the same? I'll have to watch these.
P3 motor out.jpeg (175.74 KiB) Viewed 250 times
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 175 times
Post by dikidera »
You should see the V8 turbo setup, everyone said they can't be turboed, until they can be.
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
Turbo V8= (Time + Money)^3
dikidera
Post by dikidera »
volvolugnut wrote: 20 Feb 2024, 08:09 Turbo V8= (Time + Money)^3
Or maybe not so much, except maybe a custom exhaust header.
BlackBart
Post by BlackBart »
Oh, I watched a couple of these - this is the Yamaha V8 in an S80 chassis. Most everything swaps over with factory parts from one of the two cars.
Sounds like they're going to butch it up as an "off-road" project wagon with a lift etc. No doubt lots of bars and racks and way too many lights.
I think I would have made it a low, non-XC, hotrod road wagon with nice wheels and that nice blue.
The wiki tells me:
"Although the B8444S shares its Yamaha origination, its transverse layout, and its 60 degree bank angle, officials of all three companies involved insist that the Volvo V8 is not related to the (Ford) SHO engine; the die-cast open-deck aluminum Volvo block is clearly different from the sand-cast closed-deck aluminum SHO engine block although the two engines share many common dimensions including bore centers, stroke, bearing journal diameters, and deck height."
Volvo B8444S = Bensin (gasoline) / V8 / 4.4 liters / 4 valves per cylinder / S for suction (naturally aspirated.) This engine uses original Volvo parts.
All aluminum block and heads, a bit over 310 hp, with 325 lb-ft of torque. Decent.
BlackBart
Post by BlackBart »
BlackBart
Post by BlackBart »
Ohh, Episode 4 - there is a LOT of software coordination work involved, module network communication issues, reloading software, scanning modules, getting a 2007 transmission to communicate with a 2008 module, etc etc. Not for the faint of heart it seems.
