brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
I thought my tire had been sabotaged, but it turns out my garden spikes somehow blew into the driveway. I figured it out when I returned home and put four more nails in the tire.
At this point, I’m considering getting a tube of Slime.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Your garden spikes just decided you needed studded tires now!
Has thanked: 1850 times
Been thanked: 1712 times
But didn't read the instructions. Pointy end outward................! :roll:
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
xanthefin wrote: 21 Feb 2024, 16:11
xanthefin wrote: 05 Feb 2024, 16:17
Love the progress you have made. Can the pin be obtained using Vol-fcr software?
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
ZionXIX wrote: 22 Feb 2024, 09:16
https://www.ilexa.co.uk/shop/VOL-FCR/vo ... ul-version
Sadly Vol-fcr is limited in not just years coverage (as i not just cover all 1999,2000 ECUs but P2 cars example CEM, ABS, ECM, TCM and ETM pulling info and codes with just ELM like Vida with Dice and more coming in future.. so not just K-line cable limitations) but in functionality.
Only Live data and fault codes. I heard in Finnish Volvo forums over the years it can too additionally to do check MSA15.7 Timing as advanced functionality as many has TDI Volvos here... so no i wouldn't wait it to have any these level things.
The PIN as i mentioned triggers Security Timer if put wrong more than once. Keylock professionals though knows additionally to me and many other semi professionals how rip the PIN code from IMMO easily if they have either equipment and or know how without Volvo Dealership telling it.
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
Finally got more bulbs for my instrument cluster. I'm not sure if this is normal or not but I have quite a few squares that don't turn on even with known good bulbs. Does this look normal?
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Has thanked: 1505 times
Been thanked: 3818 times
I think you have the full set there but this varies by the market for which your car was originally built.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
RedBrickCollector wrote: 24 Feb 2024, 00:31 ...Does this look normal?
Mine doesn't have the Up Arrow as it's a manual car and mine has a TRAC light between the Coolant & Lambda light
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
bmdubya1198
RedBrickCollector wrote: 24 Feb 2024, 00:31 Finally got more bulbs for my instrument cluster. I'm not sure if this is normal or not but I have quite a few squares that don't turn on even with known good bulbs. Does this look normal?
Yup, you seem to have all the lights. The blanks are either features your car doesn't have, lights that cars in your market don't have, or they are blank on all P80s.
