1998 v70 clutch master cylinder problems
ghansenv70
Year and Model: 98 v70
Post by ghansenv70 »
So I was driving. And as I goto shift I press in the clutch and hear lost of plastic snapping and the clutch pedal deceided to stay on the floor. Turns out the arm coming off the master cylinder that connects the master cylinder to the clutch pedal had snapped in half. So I ordered the new one and went to install it but when I opened the box it didn’t come with the hardware that connects the arm to the clutch pedal. I have been unsuccessful in finding what this pin or bolt is. Any help is appreciated
Has thanked: 2215 times
Been thanked: 1853 times
Can you see it on this if you use the magnify option on the drawing?
https://www.volvocarstorontoparts.ca/a/ ... 73525.html
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
ghansenv70 wrote: 17 Oct 2023, 17:54 So I was driving. And as I goto shift I press in the clutch and hear lost of plastic snapping and the clutch pedal deceided to stay on the floor. Turns out the arm coming off the master cylinder that connects the master cylinder to the clutch pedal had snapped in half. So I ordered the new one and went to install it but when I opened the box it didn’t come with the hardware that connects the arm to the clutch pedal. I have been unsuccessful in finding what this pin or bolt is. Any help is appreciatedimage.jpg
It looks like the pin has detached* itself from the pedal, you may need 9191520
The pedal shaft itself isn't solid, it's formed sheet stock seam welded, and the pins are both pressed into holes and end welded on the off side.
viewtopic.php?p=615973&hilit=9191520#p615973
Once you get the whole mess off the shaft, find somebody with tig welding skills, sometimes exhaust shops can be a resource.
.*Fatigue shear, what I should have said is it broke off. See the thread referenced, new pedal seems NLA .
Has thanked: 1614 times
Been thanked: 4078 times
That clip will slide off , then the pin drops out. Why can’t you reuse the old hardware?
foggydogg
Post by foggydogg »
That pin is likely a partial remnant of the clutch pedal assembly. I owned its twin for a time. Fabrication or a dip into the Volvo parts bin* are next.
[attachment=0]IMG_0247.JPG[/attachment
The probable failure mode was pin break, plastic break, walk.
*(Edit:
Oops. Even Skandix says NLA.)
ghansenv70
Thank you all for your help. I was digging around in the spare parts I got from when I bought the car and I got luck and found a spare clutch petal with the pin intact.
ghansenv70
My only worry now is what could of cause the stud to sheer off the clutch pedal as it would require some force. I’m hoping that the master cylinder locked up but I am starting to worry about the slave cylinder or the clutch itself
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
I think it was just wear by age or a weird coincidence. Some people run surprisingly stiff race clutches in these Volvos and don't break the stud off the pedal.
You should not be able to shear off that stud, this should hold way more pressure than humans can possibly create.
1996 855 R,
2010 V70 D5,
foggydogg
Post by foggydogg »
ghansenv70 wrote: 18 Oct 2023, 21:37 My only worry now is what could of cause the stud to sheer off the clutch pedal as it would require some force. I’m hoping that the master cylinder locked up but I am starting to worry about the slave cylinder or the clutch itself
25 years and thousands of shift cycles can fatigue any metal bits. Since it is only welded on the 'far' end of the pin, any slop in the fit on the spring side of the pedal can cause it to flex inside the hollow shaft. My guess is the problem has happened plenty of times, it just hasn't gotten much airtime. Situation status is now critical since the part is NLA. Congratulations on finding a spare. Think about fixing the old one if you can.
ghansenv70
Update some good news some bad news. The new clutch master is in and connected and the booster is back in place and the engine bay is for the most part back together. The bad news is the pedal box. Eveything is bolted in and tight and hooked together but the brake pedal has at most 2 inches of play in all directions and feels very lose. The cute pedal has play but is not nearly as bad and both pedals at not contacting there coresponding switches. I’m stumped. I know that the bolt that runs through both pedals as little plastic bushing inserts that I believe were installed and my friend said he was able to barely see installed but I personally can’t see them. And I wonder if the pedal box needs to be adjusted to contact the clutch position switch and brake switch. I don’t know next steps for either of these issues and was wondering if anyone had tips for reinstalling the pedal box or has had similar issues
