Should i change my timing belt?
reigox
Year and Model: 2004 v70
Has thanked: 2 times
Post by reigox »
I have no idea, when the timing belt was last changed and visually it looks good i think, but should i change the belt just in case?
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
first thing I did when I bought my car was change everything, belt, water pump , belt tensioner etc.
Also changed the accessory belt and tensioner.
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
And the tensioner is often the failure point, even if the belt still looks good.
FarmallM51
Year and Model: 2001 S60
Post by FarmallM51 »
I checked the year of manufacture on the timing belt label after I purchased the car to make sure it had been changed and to schedule the next one.
Has thanked: 1507 times
Been thanked: 3824 times
Timing belt gear on the P80 and P2 platforms is good quality and robust if you use OE parts, not parts from eBay , Amazon, or cheap online vendors
They last 150-200k miles.
If you buy a used car, and no have documentation of the belt, idler, and tensioner being done, plan on doing the job in the next 5000 miles or so. No reason to not drive the car in the meantime.
