Key locked inside the car, 2nd remote not unlocking Topic is solved
weitau
Year and Model: 2004 V70
Has thanked: 7 times
Post by weitau »
cn90 wrote: 24 Mar 2024, 22:33 You can do this experiment again and report back.
Do it with the driver's glass lowered and:
- Engine off
- Engine running.
In both cases, with engine off and on, so long as the first key is in the ignition, the second remote will not work at all.
2004 V70 2.4L
weitau
Post by weitau »
So I'm going to be very careful not to lock the car with the key in the ignition.
Still, I wonder why neither of my physical keys won't work in the lock cylinder. I could almost swear that it worked months ago, and I have both original keys.
Could it be because the "Alarm system" service light is on? Seems like it's hard to believe, but it's entirely conceivable.
2004 V70 2.4L
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
weitau wrote: 25 Mar 2024, 21:03
- Engine off
- Engine running.
This makes perfect sense to me as in older P80 when remote locking is handled by VGLA it too doesn't like key at ignition.
On P2 platform if you take DIM physically out Central locking wont work either as Low Speed CAN Bus connection will break.
Been thanked: 504 times
Post by cn90 »
Are you the original owner?
Maybe the ignition lock @ steering column was changed in the past?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Does the car have the deadlocks? IIRC it can't be unlocked mechanically from outside if locked from inside.
weitau
Post by weitau »
cn90 wrote: 26 Mar 2024, 06:00 Are you the original owner?
I'm the 4th owner, purchased 2 years ago and driven 11k miles. The airbag was replaced from the recall, but I don't know about the steering column or ignition cylinder. But that would explain why the key would not work on the door.
2004 V70 2.4L
weitau
Post by weitau »
vtl wrote: 26 Mar 2024, 10:30 Does the car have the deadlocks? IIRC it can't be unlocked mechanically from outside if locked from inside.
Interesting.. so I tried using the key on the door and it won't turn no matter what. Given that the window frame was a little bent when I bought the car, the previous owner must have found himself locked out before. Thanks guys!
2004 V70 2.4L
vtl
Post by vtl »
weitau wrote: 26 Mar 2024, 21:16 Interesting.. so I tried using the key on the door and it won't turn no matter what. Given that the window frame was a little bent when I bought the car, the previous owner must have found himself locked out before. Thanks guys!
Perhaps the lock is mechanically broken.
I never lock my cars when they are parked in front of the house, and it pisses me off when inlaws come to visit us and always lock them after taking for errands. Like it's a bad neighborhood =)
